Where can I get a Prekins 4 - 108 oil filter? Can I get one at Kregan - Page 2 - SailNet Community
post #11 of 17 Old 01-30-2011
snake charmer, cat herder
zeehag's Avatar
i get mine at walmart.. napa is better than wallys but..... pricing is good at wallys... all our filters are in NAPA and is easy to find em-- good guys there--
gawdIREADTHAT21DOLLARANDSPEWEDCOFFEEONSCREEN,...yi pes...not that pricey in wallys or in napa...
CHIP!!!!1 follow me when i buy parts..LOL..aint payin no retail much less retail plus 400 percent for anything....
formosa 41, cruising tropics
zeehag is offline
post #12 of 17 Old 01-31-2011
I buy my oil and fuel filters for the Perkins 4-108 from a local diesel truck parts shop. This last time they did not have the Perkins name brand fuel filter so I went with the equivalent, however I do like going with the Perkins name brand instead. The Perkins oil filter has two sizes and I've been installing the larger of the two for the past 5 years or so. The fuel filter that I replaced last year is different in internal construction than the Perkins brand and this year I'll try and return to the original brand even though it may not make a beans worth of difference. The Trans America website (tadiesel.com ) has most Perkins parts including gaskets which are hard to come by and I'll be ordering from them soon.
lancelot9898 is offline
post #13 of 17 Old 01-31-2011
Maine Member
BELLATRIX1965's Avatar
Careful with FRAM!
Fram (the orange ones) used to be the "standard" for spin-on L.O. filters - I have read of issues lately with these filters - Google same and check - so they don't seem to be as good as they once were. Things like the non-flowback valve, the relief valve (these are normally full-flow filters, and if they plug up for some reason, the relief valve allows oil to bypass the element and not starve the engine for oil), and the internal element end caps are all critical. Not to mention the filtering media itself.
The Fram PH2821a should cross to a WIX 51806 (double check me on that) - WIX has gained quite a reputation for quality filter construction - they make the "gold" NAPA filters, and are also readily available at auto part stores and Wally World. DON'T spend crazy money on "Perkins" brand filters, but DON'T risk your engine on cheapies either! Happy Motoring!
BELLATRIX1965 is offline
post #14 of 17 Old 02-01-2011
I spent $7.83 for the large perkins oil filter at a diesel truck parts store here in Maryland.(JG Parks and Son) The fuel filter was about the same price but was not the Perkins name. Haven't checked the online prices yet, but will go back to the Perkins brand on the fuel filter this spring assuming that I can buy it online and/or the truck parts place starts carrying it again.
post #15 of 17 Old 02-01-2011
Wish I never found SN!
SimonV's Avatar
Perkins 4.108 are used the world over, a majority are in farm tractors, pumps and generators. I just picked up 4 from a farm supplies at 1/3 the cost (made in Malaysia) but perkins specs. Ryco Z103 wereabout $30 here in Oz.
Simon
I miss my boat
Brisbane
DELIVERY SKIPPER
Drinking Rum before 10am makes you a Pirate NOT an alcoholic
SimonV is offline
post #16 of 17 Old 02-01-2011
I buy most of my Perkins stuff through S&W Desiel S&W Diesel, Inc. Perkins Engine Sales & Service
These guys are a great resource and will bend over backwards to help you out.
Even if you do not buy anything from them they are a good resource.
Cheers!
OceanFreedom is offline
post #17 of 17 Old 02-13-2011
Don Radcliffe
If your Perkins filter mounts with the open end down, you need to make sure that you use genuine Perkins filters or that the filters you use have an anti-flowback valve, which not all the generic cross-references do. Otherwise the oil will drain out of the filter when the engine is off, and it takes too long to build oil pressure when you start the engine.
donradclife is offline
Oil Change experience - Lessons Learned kmeeks Gear & Maintenance 33 04-16-2010 08:55 AM
Westerbeke Oil Change bossk Diesel 18 01-20-2010 06:48 AM
W60 - No oil pressure after oil change??? pma_foyl Gear & Maintenance 9 12-01-2004 09:45 AM
"Modified" Fram Oil Filter pma_foyl Gear & Maintenance 1 11-30-2004 10:01 AM
Changing Engine Oil Tom Wood Gear and Maintenance Articles 0 10-02-2002 08:00 PM
