Any pros cons on the Beta Marine engines please? - Page 3 - SailNet Community
post #21 of 33 Old 06-13-2011
Ok, so what is the difference between Universal and Beta?
Mark1948 is offline
post #22 of 33 Old 06-13-2011 Thread Starter
SanDiegoChip's Avatar
Beta is also called a koda
The Beta is also called a koda engine.
Beta Marine US Ltd. Distributors for Kubota based marine
I do not remember about the Universal but we had one in our Catalina 30. I think it was a 25 hp and they were in the Catalina 36 at least around the 1981 models.
So I guess that is no info.
One of the reasons we installed a Beta is there are two other boats of our kind (Islander Freeports) with Beats installed that I know of and one is actively cruising and just put 80 hours straight on his Beta motor on a rough seas passage. He has had zero problems with it and has put a lot of hours on it.
There is an Islander at our doc with a beta who loves it and our dock mate friend Hinze has a larger Beta in his Gulf Star 42 and loves it.
We only have about 6 hours on ours so we cannot really say much but that it works fine so far
I do think it is a well thought out engine. Easy to do maint on.
SanDiegoChip is offline
post #23 of 33 Old 06-15-2011
I installed a Beta 1505(37 hp) in my Pacific Seacraft 37 in 2006.Since then have run 1800 hrs cruising from Maine to the Bahamas.Have beaten into headseas for 3 days in the Bahamas and motored thru calms in Long Island Sound.The Beta has never missed a beat.Only maint. problem was a leaking raw water pump.Replaced in less than an hour (2 bolts-upfront).The difference between Beta and Universal is that Univ is owned by Westerbeke and the prices for parts are ridiculous.eg $475 for an engine water pump for a 5432.$85 at the Kubota dealer for the same pump with gasket.
Beta gives you the Kubota part numbers for their engines with Univ its a guess.
lastly Betas customer service is terrific,Stanley in NC is great to deal with.
Just my 2 cents
Dianne and Chuck Burke S/V NiftyNickers C37
niftynickers is offline
post #24 of 33 Old 10-16-2013
MarcGr's Avatar
Re: Any pros cons on the Beta Marine engines please?
Red,
Can you tell me where your are getting your Beta engine. I would like to talk to someone about replacing my M25XP Universal in a 1987 Catalina.
Thanks,
Marc Greenleaf 860-303-2656
MarcGr is offline
post #25 of 33 Old 10-16-2013
The most female moderator
Donna_F's Avatar
Dock
Marc,
This thread is old and they are probably no longer around but we put in a new Beta last year. It came from the dealer in North Carolina and was installed by my marina. I believe in the U.S. there's only two, one on each coast.
I have nothing but positive experiences with them from start to finish.
Donna
Catalina 30 TRBS
Rock Hall, MD
KB3ZCB
Donna_F is offline
The Following User Says Thank You to Donna_F For This Useful Post:
MarcGr (10-16-2013)
post #26 of 33 Old 10-16-2013
MarcGr's Avatar
Re: beta
Originally Posted by redhead78 View Post
Erps, hey how are you. I picked up my engine last sat, I have 6 months to commission and then the warranty starts. Where are you located and what size motor do you need. My engine came with mounts, a control panel wired that you plug into a female plug on the engine. It has standard 60 amp alt, secondary fuel filter, built in oil change pump, a TMC60E trans, both trans and throttle have brackets so you can attach your cables to. My 35 hp eng is a 4 cyl, 2800 rpm, all engines below are 3 cyl. You can add extras, for instance, I added a 100 amp alt, high exhaust stainless, a waterproof panel,wf hrs, tach, start, glow and stop buttons, wf idiot lights and buzzers. You can upgrade to "c" panel, has all guages key start, tach, hrs. I opted for the custom mount package, they made the mounts east/west or side to side exactly 20 1/4'' on center. Front to back it not usually an issue with mounts. The dealer even showed me how to make a template with the mounts on, and a piece of 1"y 8' pipe sldes thru front to rear into the stern tube. Sorry so wordy, you can email me if you want.... Red
Redhead,
I am looking to replace my Catalina Universal with a Beta. Can you tell me who you dealt with for your engine?
Thanks
Marc Greenleaf
MarcGr is offline
post #27 of 33 Old 10-16-2013
MarcGr's Avatar
Thanks Donna,
I'll check with the NC Beta people.
Marc
MarcGr is offline
post #28 of 33 Old 10-16-2013
T37Chef's Avatar
As Donna mention, contact Stanley at Beta Marine in NC. I just installed a Beta 38 this past winter, great engine so far. Well design for easy maintenance, parts are inexpensive compared to other marine engines they even list the cross reference numbers on their website, and unlike Yanmar, Westerbeake, etc they can have custom mounts made for your engine bed as they did for mine. So accurate the rear holes aligned almost perfectly.
Shawn
T37Chef is offline
post #29 of 33 Old 02-22-2017
I replaced my aging Ford 6 Ds five years ago with a pair of 75 HP Betamarine diesels. I received excellent support from the team at Betamarine. The engines run like sewing machines and noticeably the engine oil over the years has always been a clear straw colour.
Have I encountered a problem - well yes. On the Beta 75s there is at the lower part of the forward end of the raw water part of the heat exchanger a little bolt. This bolt holds a zinc anode which needs replacement every 6 - 9 months. It is an easy procedure per se ... but .... it is almost impossible, despite all precautions in way of using collecting jugs and rags .... to avoid spilling of raw seawater onto the fittings beneath. These fittings include the oil pressure sender, the 40 amp 12v fuse and wiring to the starter motor solenoid and the engine foot mounting.
Despite always taking care after a few years the oil pressure sender and its mount and connection became corroded, the engine mounting foot is corroded .... and significantly the 40 amp fuse, its holder and wires corroded away for some length. The engines could not be started.
I have de-rusted as best I can the engine mounting foot. I have carefully cleaned the oil pressure sender and its wiring. I have with difficulty replaced the totally corroded 40 amp fuse and its immediate wiring.
Given that the Beta 75 is overall such an excellent engine I am critical now some years down the line that 1/ this questionable layout makes it inevitable that changing the Heat Exchanger anode results in salt water pouring down onto critical elements. 2/ That the supplied wiring loom is of plain multi-strand copper which corrodes easily. Use of tinned multi strand copper would be so much better in a marine environment.
One learns that Good is Good but after good comes excellence. With a little more thought and attention to this sort of detail Betamarine engines could be truly excellent.
RP
Cap'n Pugsley is offline
post #30 of 33 Old 02-22-2017
Donna_F's Avatar
Dock
Originally Posted by Cap'n Pugsley View Post
I replaced my aging Ford 6 Ds five years ago with a pair of 75 HP Betamarine diesels. I received excellent support from the team at Betamarine. The engines run like sewing machines and noticeably the engine oil over the years has always been a clear straw colour....
RP
Sounds like these Betas were installed on a power boat. Might not have the same issues as on a sailboat.
Donna
Catalina 30 TRBS
Rock Hall, MD
KB3ZCB
Donna_F is offline
Beta marine Diesels engines Tequiza Terri Gear & Maintenance 2 01-17-2005 12:13 PM
Marine Radios Overview Jim Sexton Seamanship Articles 0 09-30-1999 08:00 PM
Marine Radios Overview Jim Sexton Gear and Maintenance Articles 0 09-30-1999 08:00 PM
Marine Radios Overview Jim Sexton Her Sailnet Articles 0 09-30-1999 08:00 PM
