Stored Westerbeke 46 - Page 2 - SailNet Community
post #11 of 13 Old 10-16-2012
Re: Stored Westerbeke 46
Originally Posted by renbluefish View Post
I have a Westerbeke 46 thats been sitting in heated storage for 10 years. I dont have plans for it for another 2years. The marina that stored it had rebuilt the motor before storage. I have mechanical skills but have only worked on and rebuilt gasoline motors. Plan on taking a deisel motor class. My question is should I pull the injectors and dribble some oil into them, so that I prevent any damage untill I know what i'm looking at.
The motor is in a dry basement thats heated.
I am interested in your engine,,,could you please send me an email at captwestwind@hotmail so we could exchange further information..Thanks Captcob
captcob is offline
post #12 of 13 Old 10-16-2012
Senior Moment Member
SloopJonB's Avatar
thanks, since the engine was rebuilt does that put the hours back to 0???
It's common to refer to the hours "since overhaul" or "since full rebuild". In the aircraft industry they have a term "SMOH" (Since Major OverHaul.
It's NOT considered O/K to leave that reference out and imply it's a factory new engine. That's regarded as deceptive although a properly rebuilt engine is equal to new, even better in some cases if the time was taken to "blueprint" it.
SloopJonB is offline
post #13 of 13 Old 10-27-2012
Adding Marvel will help to free up the rings. Injectors are basically nothing but high pressure check valves.(30 year diesel mech here) Soaking them could eliminate varnish that the fuel may have turned into. Most reputable marinas "pickle" engines that are known to be going into long term storage. This means they put additives in all areas,fuel, oil, & water. these additives are conducive to help in long term storage.Running the engine long enough for this additive to reach the injectors is the key.
Paladin is offline
cross index between Westerbeke 30 and ford Leyland diesel en NAVIGATORBJORN Gear & Maintenance 11 04-19-2012 11:45 AM
Westerbeke 58 Original to 1983 Boat -- Questions patjj Gear & Maintenance 4 08-28-2010 11:10 AM
Need advice on engines - Westerbeke 30B or Yanmar 3YM30? Terry60 Diesel 15 01-31-2010 02:51 AM
Westerbeke Oil Change bossk Diesel 18 01-20-2010 07:48 AM
Westerbeke opinion. maxim_rfeld Gear & Maintenance 3 04-23-2003 06:15 PM
