Stored Westerbeke 46 - SailNet Community
post #1 of 13 Old 03-15-2010 Thread Starter
I have a Westerbeke 46 thats been sitting in heated storage for 10 years. I dont have plans for it for another 2years. The marina that stored it had rebuilt the motor before storage. I have mechanical skills but have only worked on and rebuilt gasoline motors. Plan on taking a deisel motor class. My question is should I pull the injectors and dribble some oil into them, so that I prevent any damage untill I know what i'm looking at.
The motor is in a dry basement thats heated.
renbluefish is offline
post #2 of 13 Old 03-15-2010
It certainly would not hurt to do that. Most people would not bother but if you want to put in the effort, go for it. Most of the problems are a result of there being water in the cylinders that has leaked in through the exhaust but the way your engine is stored, it sounds like it is stored dry? It is still possible for everything to rust up but much less likely. Chances are if things move now, they will still move in 2 years.
You could always see whether it will bar over and make a call from there.
klem is offline
post #3 of 13 Old 03-15-2010 Thread Starter
thanks klem, I have some Marvels Mystery Oil I can use just to get the rings oiled.
post #4 of 13 Old 03-19-2010
priscilla's Avatar
Yes, squirt some mystery oil into the cylinders to prevent the piston rings from sticking to the cylinder walls...take care with those injecter sealing washers. The Westerbeke 46 is a nice engine. Contact the service department at Westerbeke when your ready to recommission, they may have some suggestions. If there's a transmission- over fill it with fluid.
Priscilla
priscilla is offline
post #5 of 13 Old 03-20-2010
2nd mate
it wouldnt hurt to turn the engine by hand a few revolutions.
Keep it airtight.
bartvdv is offline
post #6 of 13 Old 03-20-2010 Thread Starter
thanks, since the engine was rebuilt does that put the hours back to 0???
post #7 of 13 Old 10-02-2012
Re: Stored Westerbeke 46
Do you still have this engine available??
captcob is offline
post #8 of 13 Old 10-02-2012
Do you still have this engine and what kind of condition is it now??
captcob is offline
post #9 of 13 Old 10-02-2012
Every few months or so turn the motor over a few revolutions, avoiding it stopping at the same crank position each time.
If it turns over OK, I certainly would not distirb the injectors to pour oil in there. leave well alone, friend.
If it bothers you, spray some WD40 down the inlet tract and turn the motor over very slowly afterward.
Rockter is offline
post #10 of 13 Old 10-04-2012 Thread Starter
I still have the motor, dream has been put on hold. Still holding fast. Motor is still in heated storage and i have a dehumidifier maintaining humidity. Havent messed with anything yet, but it still moves. Im guessing rings havent froze. Not sure on seals but thinking of getting a motor stand and giving her a crank.
cross index between Westerbeke 30 and ford Leyland diesel en NAVIGATORBJORN Gear & Maintenance 11 04-19-2012 10:45 AM
Westerbeke 58 Original to 1983 Boat -- Questions patjj Gear & Maintenance 4 08-28-2010 10:10 AM
Need advice on engines - Westerbeke 30B or Yanmar 3YM30? Terry60 Diesel 15 01-31-2010 01:51 AM
Westerbeke Oil Change bossk Diesel 18 01-20-2010 06:48 AM
Westerbeke opinion. maxim_rfeld Gear & Maintenance 3 04-23-2003 05:15 PM
