Yanmar oil fill question - SailNet Community
post #1 of 5 Old 03-15-2010 Thread Starter
Gene T's Avatar
I can't believe I need to ask this question. My new to me boat has a Yanmar 4JH3E 56 hp engine. I am about to do the first oil change and I am puzzled.
It has the standard cap on the valve cover that I have used on every engine I have ever serviced to put oil in. However it also has an orange cap on the oil pump that shows to fill there. It also shows this in the manual but not clearly nor does not specify it must be filled here and not the other.
Anyone out there have the real scoop on this issue? Is some oil needed there just to prime the pump? Any other possible reason?
Thanks
Gene
Currently in Long Beach, CA
Gene T is offline
post #2 of 5 Old 03-15-2010
There are two since Yanmar knows some boat mfgs like to make access difficult. Either will work just fine and considfer yourself lucky if you have free access to both.
k1vsk is offline
post #3 of 5 Old 03-15-2010 Thread Starter
Gene T's Avatar
Thanks k1vsk. That actually makes sense!
Gene
Gene T is offline
post #4 of 5 Old 03-15-2010
I've got the same or very similar engine, I've filled from the top w/out a problem.
rmtayloriii is offline
post #5 of 5 Old 03-15-2010 Thread Starter
Gene T's Avatar
Good to know rmtayloriii. Thanks
Gene T is offline
Yanmar baffling black smoke Tspringer Diesel 27 08-03-2012 09:44 AM
Oil Change experience - Lessons Learned kmeeks Gear & Maintenance 33 04-16-2010 08:55 AM
'68 M34 Water Tank Fill Hose Question dancrosswis Morgan 0 04-01-2006 02:07 PM
Yanmar oil leak rskaug Gear & Maintenance 0 01-04-2004 07:08 PM
Changing Engine Oil Tom Wood Gear and Maintenance Articles 0 10-02-2002 08:00 PM
