Yanmar tranny clunks on engagement - SailNet Community
post #1 of 6 Old 03-22-2010 Thread Starter
Hello,
I have just repowered my motorsailer with a new Yanmar 4jh4ae 54hp engine. The engine is mated with a Kanzaki KM35A2 marine gear. I did the install myself but a Yanmar mechanic was on hand for the first start up. The day went pretty much flawlessly, but i did notice that the engine clunks into gear pretty hard. I was wondering if anyone has the same transmission or similar and experiences the same issue. The mechanic says it is pretty much normal for a marine gear with a cone clutch and we set the idle down a bit so it wasn't hitting so hard. Please weigh in with any personal experiences.
Thanks,
Jarod.
jarod is offline
post #2 of 6 Old 03-22-2010
I'm not sharing any personal experiences about a tranny named Yan who clunked on our engagement. I'm not even sure how you found out about her, or him, or whatever........
Oh wait I miss read that.
Yes I have lowered the idle setting to reduce a hard engagement but at the same time I have known other, non-marine, engines to live a long life with such a issue. It seems to me that in many cases it is just loud to us, not abusive to the gears but mileage may vary.
Have faith that the oceans are going to rise and flood the world, that plague and pestilence brought on by Climate Change is going to punish us for not believing. Please do as they say it is our only hope. :P
Architeuthis is offline
post #3 of 6 Old 03-22-2010
Yup. That's about the funniest reply ever
... or I'm wrong.
Living aboard, currently in the Chesapeake
O'Day 37, still new to us
CapTim is offline
post #4 of 6 Old 03-25-2010 Thread Starter
bump
jarod is offline
post #5 of 6 Old 03-26-2010
Junior Member - Cleveland
I don't know much about inboards. However, if this were happening on a rear wheel drive car it would be time for new u-joints. The concept is similar except the drive shaft on your boat connects to the prop instead of the rear axle on a car. U-joints connect spinning shafts that don't line up (rotate on the same axis). Look at the joints connecting the tranny to the drive shaft. If there is play, the bearings are worn.
itsme6582 is offline
post #6 of 6 Old 03-28-2010
Don't worry about it, Volvo-Penta uses cone clutches in all of their outdrives, and they last for ever. Cone clutches engage with a notable CLUNK, does not hurt anything. Provided engagement is not made above an idle. The prop shaft will absorb any energy, same as other types of transmissions. I have had many types of transmissions that had a clunk when engaging that lived long happy lives.
svpegasus is offline
Yanmar baffling black smoke Tspringer Diesel 27 08-03-2012 09:44 AM
Replacing our Volvo Penta Engine - Yanmar model? windtraveler Diesel 10 11-25-2010 02:59 PM
Need help YANMAR engine mount Giulietta Gear & Maintenance 20 04-15-2010 01:15 PM
Need advice on engines - Westerbeke 30B or Yanmar 3YM30? Terry60 Diesel 15 01-31-2010 01:51 AM
Prop for Morgan OI w/ Yanmar 3GM30F cwarwick Gear & Maintenance 1 11-16-2004 01:17 PM
