Question on waterpumps - SailNet Community
post #1 of 7 Old 03-25-2010 Thread Starter
2nd mate
Why don't they make the waterpump cover in some plexi or lexan, so that we - boaters - could check the vulnerable impeller without removing the damn cover?
Would plexi/lexan get black stained by the rubber impeller rubbing against it?
Or would some other material be usefull here?
Thx for your reply
bartvdv is offline
post #2 of 7 Old 03-25-2010
Because waterpump manufacturers don't care how easy the pump is to service...as they're not servicing it. Acrylic and polycarbonate are probably less abrasion resistant than the plastic currently used, which I believe is a form of ABS. ABS can not be made in a clear form as far as I know.
sailingdog is offline
post #3 of 7 Old 03-25-2010 Thread Starter
2nd mate
is there any clear plastic wich would suitable for the job?
One could easily make one him/her-self...
bartvdv is offline
post #4 of 7 Old 03-25-2010
Having a clear plastic cover through which you could look will usually do nothing more than provide you with a false sense of security. Most problems with impellers cannot be seen by simply looking straight-on at the edge except perhaps a severely torn up blade. It can't replace the thorough inspection of the entire surface of all blades, can't allow detection of cracks and deformation in the blades, can't ensure the hub isn't separated, can't determine scoring of the housing, etc...
k1vsk is offline
post #5 of 7 Old 03-25-2010
He doesn't want facts to get in his way....
post #6 of 7 Old 03-26-2010 Thread Starter
2nd mate
Yeah well, you could see: missing blades, worn out blades, dirt,...
bartvdv is offline
post #7 of 7 Old 03-26-2010
You may but my point is there are other more insidious issues with impeller blades such as a worn or loose hub , cracks, etc which cannot be seen by simply looking at it's side.
Facts apparently don't interfere with Saildogs opinion
k1vsk is offline
Quick ground question. degreeoff Electrical Systems 13 03-01-2010 07:05 PM
Stupid Question krozet Boat Review and Purchase Forum 15 10-11-2009 11:30 AM
Ladder question mcain Gear & Maintenance 14 08-03-2007 10:28 PM
Cruising home/base/marina ICW question thorJ30 General Discussion (sailing related) 3 05-30-2005 05:53 PM
