Diesel Engine Replacement (Yanmar 2QM20) - Recommendations - SailNet Community
post #1 of 3 Old 03-30-2010 Thread Starter
I am replacing a Yanmar 2QM20 with a 2QM15 in a Catalina sailboat due to a cracked head and block. My question is, are there any helpful hints in disconnecting and removing the engine and transmission from the shaft.
The current engine is completely disconnected and ready to be removed. The only remaining procedure is to disconnect the transmission from the shaft, remove the bolts holding down the motor mounts, and hoisting out the engine.
Upon reinstallation, I do plan on having a mechanic re-align the transmission.
I have been told that once the transmission is removed from the shaft, that there may be excess water leakage through the seal.
Thank you for your time and any help.
westannapoliscrew is offline
post #2 of 3 Old 04-01-2010
JimsCAL's Avatar
Sounds like you are in the water. I see no reason why the stuffing box should leak excessively once you disconnect the engine.
JimsCAL is offline
post #3 of 3 Old 04-07-2010
Red
I would try to either hang the shaft in place, or maybe a small piece of wood across to try to keep the shaft as close to where it is when bolted up to the trans. Red
Red, 77 Jeanneau Gin Fizz 38
redhead78 is offline
Diesel Engine Replacement - Yanmar 2QM20 westannapoliscrew Diesel 0 03-30-2010 04:45 AM
Runaway Diesel Engine Ben Hilke Gear and Maintenance Articles 0 07-19-2004 08:00 PM
Surveying a Diesel Engine Tom Wood Buying a Boat Articles 0 01-26-2003 07:00 PM
Surveying a Diesel Engine Tom Wood Gear and Maintenance Articles 0 01-26-2003 07:00 PM
Replacing the Diesel Engine Sue & Larry Gear and Maintenance Articles 0 06-12-2000 08:00 PM
