Cruising RPM - Page 3 - SailNet Community
post #21 of 22 Old 04-09-2010
Originally Posted by Omatako View Post
Really?
You've got distance and time to factor into the equation.
lancelot9898 is offline
post #22 of 22 Old 04-11-2010
Are you saying that you are trying to balance fuel consumption versus your own time? I find the easiest graphs to read the ones that compare fuel consumption/power versus rpm. On most diesel engines, this will occur near the torque peak. This can be manipulated a little through things like timing but not much. At high rpms (which I would consider 80% to be), you are putting a lot of energy into simply spinning the engine which is also not running as efficiently. 80% is perfectly acceptable if you want to get somewhere relatively quickly but it is not going to yield optimal fuel economy.
klem is offline
Retirement Cruising Budgets Randy Harman Cruising Articles 0 05-12-2004 08:00 PM
Calculating the Cost of Cruising Paul & Sheryl Shard Cruising Articles 0 04-03-2003 07:00 PM
Calculating the Cost of Cruising Paul & Sheryl Shard Her Sailnet Articles 0 04-03-2003 07:00 PM
