Bleeding a Westerbeke 33 ? - SailNet Community
post #1 of 5 Old 04-08-2010 Thread Starter
A friend is moving my sailboat, and I'd like to give him some instructions for bleeding the fuel lines in case he encounters any issues.
It's a long story, but the boat is a new purchase and in another country, and I haven't had the pleasure of tinkering with it. The engine is a 1984 Westerbeke 33.
Anyone familiar with this engine and able to give a quick bleed procedure for me? Thanks so much,
nick.
Bigoceans | Tiny Boat
nickj is offline
post #2 of 5 Old 04-08-2010
CarelessNavigator's Avatar
According to this brochure from 1986 it states that it has a self bleeding fuel system. Don't know if any changes were made between 84 and 86.
1986 Westerbeke33 Brochure
Here is a manual for a Westerbeke generator. There are some decent graphics of the fuel system around pages 39-41. The fuel system should be very close the 33. It might help for explanation or familiarization of what is what to your friend. Westerbeke Generator Manual
I don't know if that helps you out or not.
CarelessNavigator is offline
post #3 of 5 Old 04-08-2010
Most westerbrekes I've dealt with are self-bleeding... If it was another brand, I'd be worried about getting a diagram to him.
sailingdog is offline
post #4 of 5 Old 04-08-2010
chucklesR's Avatar
Westerbeke uses a 12v electric fuel pump on all of it's engines. That makes them self bleeding.
All you have to do is turn the key to on and push in the 'pre-heat button', give it 1 minute if bleeding, 10-12 seconds on a cold start and 4-5 on a warm start, then push the starter. Should be the same on either the 'captain's' or the 'admiral' version.
Carry spare fuel pumps though. Any 12v marine rated diesel pump at 22 or so gph will do, WB parts are expensive. Obviously not as reliable per se as a mechanical pump, and there is no manual/mech backup.
The thing to do is to change the old filter first, as you have no idea how many hours it has on it. Then you don't need to worry about bleeding. I'd also carry a set of spare engine fuses (should be 10 amp, not sure that model). Bites to have a dead engine for want of a spare filter or fuse.
chucklesR is offline
post #5 of 5 Old 04-12-2010 Thread Starter
Thanks everyone, your help is much appreciated -
My friend is moving it this weekend, I'll let you know how it goes!
Nick
nickj is offline
cross index between Westerbeke 30 and ford Leyland diesel en NAVIGATORBJORN Gear & Maintenance 11 04-19-2012 10:45 AM
Westerbeke 58 Original to 1983 Boat -- Questions patjj Gear & Maintenance 4 08-28-2010 10:10 AM
Need advice on engines - Westerbeke 30B or Yanmar 3YM30? Terry60 Diesel 15 01-31-2010 01:51 AM
Bleeding problems on a Yanmar diesel engine stella7maris Diesel 11 12-02-2009 04:23 PM
Westerbeke opinion. maxim_rfeld Gear & Maintenance 3 04-23-2003 05:15 PM
