Yanmar 2GM20F Work... - Page 2 - SailNet Community
post #11 of 16 Old 04-28-2010
trantor12020's Avatar
krozet, one of your v-belt, the outer one, seems to be fitted reverse. if I'm not wrong, the notch side should be facing the pulley.
Ken
2002 Hunter 326, SV Millennium 2
1999 Macgregor 26X, SV Millennium
trantor12020 is offline
post #12 of 16 Old 04-28-2010
JimsCAL's Avatar
I'm pretty sure its OK. Some belts are made that way. It would be tough to get the fat side of a v-belt to even go in the pulley.
JimsCAL is offline
post #13 of 16 Old 04-28-2010
kroz check the manual before adding to the tranny,if i recolect it dont take much and too much is a problem...good luck
norsearayder is offline
post #14 of 16 Old 04-28-2010
My thoughts too... on the Hurth the 'mark' is only 1/4 or 3/8" up the 'dipstick'..
Faster is online now
post #15 of 16 Old 04-28-2010 Thread Starter
Waiting For Spring
krozet's Avatar
Hey Faster;
Yeah I refereed to the manual, the problem was that the fluid was so low that it wasn't registering on the dipstick... The very bottom of the dipstick (the underside of the dipstick) had a smudge of fluid but nothing on the stick. The transmission plate listed that it took next to no fluid (.3 quarts I believe?) so I added maybe 4 tablespoons. Now it registers on the dipstick half way between the bottom and the mark.
Robert
1971 Contest 33 Hull Number 24
"Twenty years from now you will be more disappointed by the things that you didn't do than by the ones you did do. So throw off the bowlines. Sail away from the safe harbor. Catch the trade winds in your sails. Explore. Dream. Discover."
Mark Twain
krozet is offline
post #16 of 16 Old 04-28-2010 Thread Starter
Waiting For Spring
krozet's Avatar
Hey;
I didn't remove the belts, they also narrow towards the bottom to fit in the groove on the pulley. My concern is that both belts seem a little loose and the tool that the manual says to use too tighten them I don't have.
Robert
Mark Twain
krozet is offline
Need advice on engines - Westerbeke 30B or Yanmar 3YM30? Terry60 Diesel 15 01-31-2010 01:51 AM
yanmar 2GM20F oil burner seadog47 Diesel 11 10-16-2009 06:34 AM
Yanmar 2GM20F Petar Gear & Maintenance 13 10-02-2009 06:49 PM
Eye-splicing lines... beatkiddo Seamanship & Navigation 11 09-20-2006 01:28 PM
Superfluous Sextant? akoutdoors1 Seamanship & Navigation 4 08-10-2006 10:51 AM
