Removing Engine - SailNet Community
post #1 of 8 Old 04-18-2010 Thread Starter
titan151's Avatar
Removing Engine
I have an MD7A that I am removing from the boat to do some work on. Anyway, the last connection I need to break is between the transmission and the shaft. I figure I can either try and turn the 2 square headed bolts or perhaps remove the coupling (with four bolts) from the transmission? Anyone done something like this before?
titan151 is offline
post #2 of 8 Old 04-18-2010
bljones's Avatar
remove the coupling. Take care to lubricate those bolts well, clean the holes well before inserting the correct six- point bit, and be judicious with torque when attempting to remove them- the are easy to strip.
bljones is offline
post #3 of 8 Old 04-18-2010
It will be easier to unbolt the coupling from the transmission. Trying to take the coupling off of the shaft while attached to the engine would not be very easy. From the picture it looks like hitting the bolts with penetrating oil once or twice a day for a week might make the process a lot less painful. That does assume that you are not in a big rush.
klem is offline
post #4 of 8 Old 04-18-2010
I have done this, agree with the advice above. I treated those rusty bolts with Kroil all winter. In the spring they unbolted with ease. Some like PB Blaster.
WanderingStar is offline
post #5 of 8 Old 04-18-2010 Thread Starter
titan151's Avatar
Thanks all,
They came out with no problem. I thought they were going to give me quite a battle. That and I still have skin on 9 out of 10 knuckles.
titan151 is offline
post #6 of 8 Old 04-21-2010
Titan,
You win!...
grab yourself some grade 8's - for bolt head strength... or (if you wanna go all goofy, totallystainless. com has them in grade 8.) and a 4 oz can of never seez, available @ any decent autoparts store. Use "never seez" on reassembly for anything you might want to take apart again. (careful, once you put the can in the car for the ride home, that stuff is ALL OVER you.) slobber it on the new bolts and congratulate yourself with an adult beverage.
We are not primarily on earth to see through one another, but to see one another through
Some people are like slinkies: not really good for anything... but you can't help laughing when you push them down the stairs
cardiacpaul is offline
post #7 of 8 Old 05-04-2010
Locktite make a product that suppsedly freezes and unlocks rusty bolts
I have not had one success in about 50 trys
Waste of money
tytower is offline
post #8 of 8 Old 05-04-2010
Jeez you must must be a soft touch if you believe that . In my world its every poster for himself .....almost there , can go do another post on crimpers which is where I really want to be
tytower is offline
Runaway Diesel Engine Ben Hilke Gear and Maintenance Articles 0 07-19-2004 08:00 PM
Caring for the Cruising Outboard Doreen Gounard Gear and Maintenance Articles 0 04-22-2003 08:00 PM
Surveying a Diesel Engine Tom Wood Buying a Boat Articles 0 01-26-2003 07:00 PM
Surveying a Diesel Engine Tom Wood Gear and Maintenance Articles 0 01-26-2003 07:00 PM
Replacing the Diesel Engine Sue & Larry Gear and Maintenance Articles 0 06-12-2000 08:00 PM
