Replace fresh water pump? - SailNet Community
post #1 of 3 Old 04-22-2010 Thread Starter
I've got a Yanmar 4JH2E (1994) with about 2,800 hours on it. It looks like the fresh water pump has never been replaced. I was replacing hoses today and noticed that there is a fair amount of corrosion and pitting on the metal at the hose connections. Should I replace the pump as a preventative measure? I'm asking because it looks like they cost about $270. Does anyone know how long these pumps typically last?
SteveInMD is offline
post #2 of 3 Old 04-22-2010
If there is a lot of corrosion on the outside of the housing, it usually signifies that connection was leaking. It is up to you to judge how corroded it is and whether it actually represents a problem or not. If a hose connection snaps off, you won't be able to use the engine until the pump is replaced so keep that in mind.
Usually what happens to water pumps is that the seals start to go in them which can be diagnosed by water coming out of the weep hole. It would be hard to give the pumps a life span since some environments have much worse corrosion.
klem is offline
post #3 of 3 Old 04-22-2010
Given the age of the pump, corrosion on it and pitting, replacing it might be wise and prudent.
sailingdog is offline
Fresh Water Pump won't self-prime...any tips? scraph Gear & Maintenance 5 04-26-2011 01:37 AM
St. Maartin, St. Barts & Anguilla bbayer4230 Chartering 2 04-23-2006 07:04 PM
Water, Precious Water Michael Carr Cruising Articles 0 09-02-2004 09:00 PM
fresh water tank, tastes like ****! nauticalrich Gear & Maintenance 6 05-24-2002 05:17 PM
