Serial number of old YANMAR YSE8 - SailNet Community
post #1 of 6 Old 05-04-2010 Thread Starter
I have some problem with local YANMAR dealer in Italy because he don't recognize the serial number of my old YSE8.
I need just a confirmation that the s/n of these old models is composed by four number only (ex.: 5234) , without any character at the beginning.
If somebody own this engine, I appreciate this help.
Thanks
Marco
Markolone is offline
post #2 of 6 Old 05-16-2010
okawbow's Avatar
Hello Marco,
I looked at my YSE8 today, and the only numbers on the front of the block, were- 76, then under that, was 2, under that was 21, and under that was 226. I don't know if any of these is the serial number, but it looks like the first part is the date of manufacture. On the metal tag, located on top betwee the motor and transmission, were- Yanmar YSE8, and the letters or numbers- ISO
Hope this helps. Are you rebuilding or repairing?
Chuck
Privateer 26 Schooner
okawbow is offline
post #3 of 6 Old 05-17-2010 Thread Starter
Hello,
thanks for your reply.
I bough the boat and engine 3 years ago in France, and now I have problem about formal documentation. The Italian dealer sais that the serial number at the top/rear is not valid (but I red somewhere that is right for the older models).
I think that your s/n is 226, because your model is YSE (Early); mine is YSB (Between - I found now on the label) and the newest is YSE (Modern).
In any case I don't find anything on the front.
The engine actually run perfectly but this nuber is mandatory for the insurance (I lost the original documents).
I have all the original documentation about maintenance but there isn't information about s/n location.
P.S.: all YS are great engines and 3 years ago I found in UK an original spare part.
[IMG]c:\marco\mavi hen\matricola yanmar\matricola yanmar 2.jpg[/IMG]
post #4 of 6 Old 05-17-2010
okawbow's Avatar
There should be numbers cast in the front of the block, just below the head. You might have to clean the metal off to see them. i'm sure the YSB8 used the same block as the YSE8.
Chuck
okawbow is offline
post #5 of 6 Old 05-19-2010 Thread Starter
Finally I found the serial number in the front of the block, under some rust.
Thanks Chuck!
post #6 of 6 Old 05-19-2010
okawbow's Avatar
Good for you!
Those little motors are easy to work on, and dependable. If you don't have a manual, you can downlaod one at Blank
Good luck
Chuck
okawbow is offline
Installing any tach on a YSE8 Yanmar?? Windemere Electronics 6 05-05-2015 08:00 AM
Yanmar baffling black smoke Tspringer Diesel 27 08-03-2012 09:44 AM
FYI: To all owners of Yanmar Diesels -YSM8 -found fix to stall problem jrowan Diesel 2 04-14-2010 08:37 AM
Yanmar YSE8 - Runs fine then stops after an hour or so - Ideas why ? publicbar Diesel 11 12-16-2009 09:38 PM
serial number for sailboat Cobra160 General Discussion (sailing related) 4 09-19-2009 11:38 PM
