Yanmar 3HM35F Oil Capacity - SailNet Community
post #1 of 4 Old 05-10-2010 Thread Starter
Not Finished Yet
RainDog's Avatar
Changing my oil. Stated capacity in my service manual is 5.7 quarts. I just extracted 4 quarts using a vacuum extractor. I pushed the extractor tube straight into the dipstick tube until it hit bottom. Before the change the oil was right between the two lines on the dipstick.
Are there still 1.7 quarts in there? If so, any idea how to get to them?
The manual says to add 5.7 quarts at this point, but I don't think I will be doing that.....
RainDog is offline
post #2 of 4 Old 05-10-2010
Moderator
JohnRPollard's Avatar
Did you change the filter, too?
Presumably that 5.7 qt capacity includes the filter. I like to drain the filter into the used-oil container so I can get a better idea of what was extracted from the engine. Still, there's always less than the rated capacity, even though the dipstick registers full.
You can't get it all out. But I'd think you'd have a smaller discrepancy than 1.7 quarts, even if you didn't change the filter.
JohnRPollard is offline
post #3 of 4 Old 05-10-2010 Thread Starter
Not Finished Yet
RainDog's Avatar
I did change the filter, and did not mesure that, but I do not think that could account for more than a pint.
However after the oil change and running it for 5 minutes, the oil looks pretty clear still, so I guess I got most of it. Maybe .7 quart from the filter and oil in the engine and the other quart because it was halfway between the two lines on the dipstick?
RainDog is offline
post #4 of 4 Old 05-11-2010
Moderator
Sounds about right. Down a pint to begin with, a half pint in the filter, and maybe a pint that just can't be extracted. That gets you pretty close.
If you're topped off and it looks clean, you should be good to go. Just check it again after a few hours and see how it looks.
I will say, that I usually get much closer to the correct amount. Within a few tenths of a quart.
Anyway, this coming from a 3GM owner. It would be good to hear from some 3HM owners to see how close they get.
Yanmar baffling black smoke Tspringer Diesel 27 08-03-2012 09:44 AM
2003 Yanmar, 765 hours - milky oil, overheating, evacuating coolant vpo3 Diesel 2 05-10-2010 11:33 AM
Oil Change experience - Lessons Learned kmeeks Gear & Maintenance 33 04-16-2010 08:55 AM
Yanmar oil fill question Gene T Diesel 4 03-15-2010 09:20 PM
Changing Engine Oil Tom Wood Gear and Maintenance Articles 0 10-02-2002 08:00 PM
