no fuel at injectors - Page 2 - SailNet Community
post #11 of 12 Old 06-10-2010
okawbow's Avatar
I have an Albin diesel that takes quite a while for the fuel to get from the high pressure pump to the injectors after air has got to the system. When I see fuel coming out; is is only small drops that are spit out, not a lot of fuel. I doubt there is a problem with your pump.
Try starting at the filter, and bleeding the system to the h/p pump. Take the h/p fuel lines off the top? of the pump and see if you get fuel. If you do; put the lines back on and pump until you get fuel to the injectors. Mine takes about 30 seconds of hand cranking to fill up the lines. Be sure your fuel lever is at least 1/2 and the kill pull is off and hasn't slipped somehow.
Chuck
Privateer 26 Schooner
okawbow is offline
post #12 of 12 Old 06-10-2010 Thread Starter
chuckg5's Avatar
Great suggestions, many thanks!
tommorow I'm going down to the boat and try all of this.
chuck
chuckg5 is offline
Dr. Diesel, Foley Engines, and me... skipgundlach Diesel 43 04-28-2016 04:16 PM
Rebuild Injectors - Fuel Consumption? T37Chef Diesel 12 03-10-2010 04:35 PM
Diesel Fuel Essentials Tom Wood Gear and Maintenance Articles 0 03-22-2004 07:00 PM
Diesel Fuel Essentials Tom Wood Her Sailnet Articles 0 03-22-2004 07:00 PM
Diesel Fuel Concerns SailNet Gear and Maintenance Articles 0 07-08-2002 08:00 PM
