Lose sea water flow in my M25 - SailNet Community
post #1 of 7 Old 06-10-2010 Thread Starter
obleo
Something has happen twice this year that has never happen before (I've had the boat for 6 years). I go out sailing, the engine runs fine. After I sail and start the engine, I get no water flow. I check everything and find nothing wrong (no weeds or blockage). I disconnect inlet to the water pump and I suck the water to the pump, reconnect it and the engine runs fine. It's like I am loosing prime to the pump when I'm sailing. I have a heat exchanger system. Any thoughts?? Thanks in advance for any help.
obleo is offline
post #2 of 7 Old 06-10-2010
Gene T's Avatar
How is the impeller?
Gene
Currently in Long Beach, CA
Gene T is offline
post #3 of 7 Old 06-10-2010 Thread Starter
obleo
Impeller looks fine. I don't want to change it until i find out what the problem is.
obleo is offline
post #4 of 7 Old 06-10-2010
BarryL's Avatar
Hey,
Are you heeling so much that the raw water intake comes out of the water? I certainly hope not!
I would guess that either the impeller is worn or the pump is worn. As they get worn, the pump loses the ability to generate a lot of suction. I would first change the impeller to a new one and if that doesn't work I would change the pump.
Good luck,
Barry
Barry Lenoble
Deep Blue C, 2002 C&C 110
Mt. Sinai, NY
BarryL is offline
post #5 of 7 Old 06-11-2010
I had an impeller break free from the shaft, so the shaft would spin but the impeller did not move. I'd replace the impeller and see what happens.
saildog1 is offline
post #6 of 7 Old 06-11-2010 Thread Starter
obleo
I emailed Moyer Marine with this problem and Don replied. I think it is amazing that he answers any time I have a question. Everyone go buy something from Moyer.
Anyway, he says that the water should always flow easily to the intake of the pump. That doesn't seem to be happening. I have a basket filter that when the top is opened, no water comes out even with the thru hull valve open. Maybe the first step is to lower this filter? I would have to close the thru hull to inspect the basket but that's no big deal.
He also says that an old impeller can wear the inside of the impeller section. Maybe that has happened to the point that the pump can't overcome the improperly placed filter?
obleo is offline
post #7 of 7 Old 06-11-2010
Here are couple of questions to trouble shoot where your problem is:
1. Is the water not coming out of the exhaust only when you are motoring under sail (heel is involved) or also when you are just motoring (no heel)? If you have the problem only when boat is heeled over the problem may be simple. If otherwise, read on.
2. If you are not having water come out even while motoring I would recommend testing at the dock to do further checks. Note that in this situation the engine will heat up as the cooling water is not passing through the engine.
It also seems that you have a water strainer (basket filter you mentioned) between the raw water intake through hull and the water pump.
2a. First run the engine as is at the dock with everything connected and see if you are having water come out. Assuming you have a problem read on..
2b. Turn the engine off. Remove the hose that goes from the thru hull stop **** to the input of the water strainer. Remove it from the stop **** side. Put that side in a bucket full of water and start the engine. Keep a water hose connected to the dock water supply handy to fill the bucket if the water goes down below half level. As you run the engine see if the water level goes down. if it does the water pump is taking in the water and the same should come out of the exhaust. If this happens you have a clogged thru hull. If the water does not come out continue ahead.
2c. Remove the hose from the other side of the strainer. This hose goes to the water pump input. Put this end of the hose in the bucket (you have have to extend it) and recheck. If you now get water out of the exhaust, you had a problem with the strainer. A clog or an air leak. Fix it and recheck. If the water still does not come out, read on...
2d. Now it is only the water pump left to check. Open up the water pump and check the impeller. Check the soundness of the stem, the blades etc. Also check that when the impeller is in the water pump, the blades are a bit bent when they pass under the cam. Given that you say you don't have any water coming out in situations, I don't think your problem is that of a worn inside section. That will reduce the water flow not completely stop it. If you have come this far there is a evident problem with the water pump and you should be able to see it.
My guess is that you will find your problem in 2a, b or c. Let's see what you find. Post a message if you have questions or if anything above is not clear.
Please make sure to note down where you remove stuff from so you can ut it back together. Also check the working of the engine thoroughly at the dock before taking the boat out after the troubleshooting.
SeaFever2000 is offline
Sea Water Strainer joub Gear & Maintenance 14 10-22-2015 05:35 PM
When Tragedies Happen at Sea SailNet Cruising Articles 0 05-28-2002 09:00 PM
