Kubota diesel troubles - SailNet Community
post #1 of 14 Old 06-12-2010 Thread Starter
Send a message via AIM to gypsy22 Send a message via Yahoo to gypsy22 Send a message via Skype™ to gypsy22
Kubota engine seems to have trouble turning over... It will with much time/effort, but it's struggling mightily. Suggestions?
gypsy22 is offline
post #2 of 14 Old 06-12-2010
Handsome devil
Stillraining's Avatar
Little more info needed
1) does it seem locked up as in , it will only turn a tiny bit with each turn of the key....Possibly Hydraulically locked or badly rusted by water through the exhaust ports.
2) how long has it been sitting unused or if used regularly when did this start happening?...and what were you doing right before this all came about?
3) Don't think these a dumb question OK...Is your battery fully charged? and all connections CLEAN?
4) Are you out of gear?
5) How old is the starter?...do you have an amp meter to check starter draw?
"Go Simple...Go Large"
Relationships are everything to me..everything else in life are just tools to enhance them.
The purchase price of a boat is just the admittance fee to the dance...you still have to spend money on the girl...so court one with something going for her with pleasing and desirable character traits others desire as well... or you could find yourself in a disillusioned relationship contemplating an expensive divorce.
Stillraining is offline
post #3 of 14 Old 06-12-2010
obleo
I always check all battery connections first. Seems like the engine ground is always the one that corrodes and causes problems.
obleo is offline
post #4 of 14 Old 06-12-2010
Courtney the Dancer
jrd22's Avatar
I agree with Still, need more info.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
jrd22 is offline
post #5 of 14 Old 06-15-2010
Doesn't sail enough
Mwozniak's Avatar
I have a 31 year old Yanmar 2GM that seems to have seized up in the past 60 days since it last ran (damned job got in my way from my life priority) new battery, new starter, not in gear, won't hand crank even with my 230lbs on the handle. may resort to C4. Ideas?
Mwozniak is offline
post #6 of 14 Old 06-15-2010
Doesn't sail enough
Mwozniak's Avatar
have you released your compression and tried turning it over by hand?
Mwozniak is offline
post #7 of 14 Old 06-19-2010 Thread Starter
Hey all,
sorry for late response-- was working on the clipper round the world yachts all week (very cool).. Anyway, as you asked :
1) does it seem locked up as in , it will only turn a tiny bit with each turn of the key....Possibly Hydraulically locked or badly rusted by water through the exhaust ports? Doesn't seem that way.. It does turn over a little, but it's almost like it's choking, or forcing the issue... Certainly not reliable if I were to get caught offshore.
2) how long has it been sitting unused or if used regularly when did this start happening?...and what were you doing right before this all came about? Engine was winterized, and beforehand was owned by someone who kept boat moored almost always.
3) Don't think these a dumb question OK...Is your battery fully charged? and all connections CLEAN? Have had previous battery issues; theyve since been replaced, and connections are clean yes.
4) Are you out of gear? Certainly not ;-)
5) How old is the starter? Starter is older, but was checked twice and seemed ok...
gypsy22 is offline
post #8 of 14 Old 06-20-2010
Omatako's Avatar
If you have salt water in the cylinders, the engine will not budge and without stripping and possibly a 4 pound hammer you will have no movement at all.
Arthur C. Clarke
Omatako is offline
post #9 of 14 Old 06-20-2010
JimsCAL's Avatar
Try this! It will determine if its friction in the engine or a weak starter or battery.
JimsCAL is offline
post #10 of 14 Old 06-20-2010
Kubotas do not have decompression levers, you would have to remove the injectors to achieve this.
r.furborough is offline
Dr. Diesel, Foley Engines, and me... skipgundlach Diesel 43 04-28-2016 04:16 PM
Diesel Fuel Essentials Tom Wood Gear and Maintenance Articles 0 03-22-2004 07:00 PM
Diesel Fuel Essentials Tom Wood Her Sailnet Articles 0 03-22-2004 07:00 PM
Gas versus Diesel Tom Wood Gear and Maintenance Articles 0 01-10-2002 07:00 PM
The Diesel Generator Mark Matthews Gear and Maintenance Articles 0 03-25-2001 07:00 PM
