Yanmar 2GM Oil leak - SailNet Community
post #1 of 9 Old 06-15-2010 Thread Starter
Yanmar 2GM Oil leak
I just got back from a trip in the Gulf - Motor Sailing most of the way. I had the engine running about 2300 RPM for 10-12 hours some days - 24 hrs some days. The Gulf was very rough so the boat was heeled and had the rails in the water a good portion of that time. Every 12 hours I would shut the engine down to check the oil level and add oil- most of the time it was about a pint to a quart low. When returned to the slip, noticed that there was about a quart of oil in the pan below the engine - no obvious signs of a leak. Is it possible that the oil could come out the dipstick tube when the boat is heeled?
bclay3 is offline
post #2 of 9 Old 06-16-2010
JimsCAL's Avatar
I am puzzled why you are running the engine if there is enough wind to put the rail in the water. Running the engine at that angle for hours on end is not good for the engine. I suspect operating the engine that way is the cause of the oil loss.
JimsCAL is offline
post #3 of 9 Old 06-16-2010 Thread Starter
Yanmar 2GM Oil leak
Why run the engine with the rail in the water?
The Gulf is often frustrating sailing. Takes about 4 hours to get it kicked up - 4-5' seas - with 6 sec period. Then the wind dies completely - it often takes 18 hours for the seas to settle down so unless you want to bob for 12 to 18 hours - you fire up the engine and if you were on a reach then the rail is in the water with no wind - even with the waves on the stern, the boat is anywhere but level for idea motoring.
bclay3 is offline
post #4 of 9 Old 06-16-2010 Thread Starter
JimsCal - Thanks you for your input - confirms what I suspected -
Bud
bclay3 is offline
post #5 of 9 Old 06-18-2010
Motoring with the rail in the water is likely to cost you one motor.
Very few motors will tolerate sustained heel like that.
Your first warning is likely to be a loud clatter, a whine, then it will stop.
Rockter is offline
post #6 of 9 Old 06-18-2010
imagine2frolic's Avatar
Make sure your breather tube is not plugged. It could be forcing oil out where there would be no leak.........i2f
20 MPH ain't fast unless, you do it in a 1000sq 3/2 house on 10foot waves
BORROWED, No single one of us is as smart as all of us!
imagine2frolic is offline
post #7 of 9 Old 06-19-2010 Thread Starter
Thanks, I'll check it -
bclay3 is offline
post #8 of 9 Old 06-19-2010
Well I donītsee much reason for concern at running the motor heeled over. Look at the design of the motor (what type is it?) . The oil sits in a pan underneath the crank and pistons etc and the oil pump lifts oil to all the points it is needed.
So if the oil pressure gauge is where it should be for your motor then you will do no harm.
If pressure falls you must stop it immediately as the bearings run on that oil pressure between the parts.
The only other consideration is the lower portion of the bores and the piston pins are splash lubricated by the churning parts and oil returning to the sump. I donīt see that this would cause you any concern as your whole motor would be on the move all the time.
As far as leaks are concerned you must clean up the motor nicely everywhere ,put some paper or white rags down ,run it and look for leaks . My suggestion is put paper under the front pulley and under the bell housing . Oil seals may be worn or blown from overfilling.
Usually dip stick tubes are long enough to accommodate almost sideways running. Some out the breather is also possible on older engines or modified engines .
tytower is offline
post #9 of 9 Old 06-19-2010 Thread Starter
Thanks for the input - puts my mind at ease about running the engine when the boat is heeled as sometimes it is absolutely necessary for safety sake.
Also appreciate the suggestion about the paper or rags under the the oil pan.
bclay3 is offline
Yanmar baffling black smoke Tspringer Diesel 27 08-03-2012 09:44 AM
Teak refinishing and repair Waterline Gear & Maintenance 21 06-10-2010 02:21 PM
Oil Change experience - Lessons Learned kmeeks Gear & Maintenance 33 04-16-2010 08:55 AM
Yanmar oil leak rskaug Gear & Maintenance 0 01-04-2004 07:08 PM
Changing Engine Oil Tom Wood Gear and Maintenance Articles 0 10-02-2002 08:00 PM
