How to bleed diesel without a mess - SailNet Community
post #1 of 9 Old 06-26-2010 Thread Starter
One of None
deniseO30's Avatar
No matter how careful anyone is (me included) some of the fuel gets on the engine and runs down to the bilge. Is there a way to bleed diesels without getting the mess? I know on cars and trucks there's a way to connect a hose to the bleeder. I know.. I think too much
My last project!
deniseO30 is offline
post #2 of 9 Old 06-26-2010
Gary M's Avatar
I guess it would depend on your set up. I bleed the primary Racor by putting a little dish under it to catch any spills then hold some paper towels at the vent which absorbs most of it.
I then move on to the small vent on the Yanmar filter mounted on the front of the engine. I just open the vent and hold paper towel over it until all the air is out. Close it and am done. So far I have never had to bleed the injectors.
Doing this I get a little on my hands but none in the bilge.
Which reminds me I need to change my filters today.
Gary
Gary M is offline
post #3 of 9 Old 06-26-2010 Thread Starter
One of None
deniseO30's Avatar
And later that evening while eating crabs they have a nice oily aroma that coming from OH! your hands! rags, dishes, cups, paper towels are part of the mess Gary! I bet a machinist could make a bleeder that has a hose connection with an o ring in the body so the fuel only goes in the tube not out the bleeder screw. But then.. who would bother LOL
My last project!
post #4 of 9 Old 06-26-2010
TQA
Bombay Explorer 44
TQA's Avatar
TO EAT CRABS WITHOUT TASTING THE DIESEL
Get a box of disposable latex gloves - less than $10 from most parts stores.
Stops you having to wash crab juice off your hands too.
I suppose you could even wear them when bleeding the diesel system.
TQA is online now
post #5 of 9 Old 06-26-2010 Thread Starter
One of None
deniseO30's Avatar
Nope! some people have latex intolerance! LOL guess I'll stick with the paper towel method
My last project!
post #6 of 9 Old 06-26-2010
Crealock 37
sailak's Avatar
Dock
Latex free gloves are your friend.
Dale
S/V Elnora
Pacific Seacraft "Crealock" 37 #312
sailak is offline
post #7 of 9 Old 06-27-2010
Denise—
Use nitrile gloves.... for two reasons... 1) Latex is a very nasty material for people allergic to it... 2) Latex dissolves in petroleum products...Nitrile doesn't.
Also, carry some alcohol-based hand-sanitizer on your boat. It will do an amazing job of removing the residual diesel fuel from your skin and kill any germs in the process.
BTW, you could always do what Westerbreke and some other engine manufacturers have done... install an electric fuel pump to bleed the system. Generally, you don't even need to open any bleeder screws or anything... since the air just gets pushed through the system.
Many electric fuel pumps are pass-through designs, where the fuel will pass through the pump if it is off, so you don't even need to install a diverter system.
sailingdog is offline
post #8 of 9 Old 06-27-2010
KVK
I recently had the challenge of changing filters on a 5411, and then try to crank the diesel engine to bleed the air out. I opted to install a fuel bulb between the tank and first fuel filter. A couple of squeezes on the fuel bulb, pressurizes the line and "controls" the bleeding process with a single stream vs. a pulsating stream from fuel pump. Anyway, it did the trick and the mess was easy to catch with fuel diapers.
KVK is offline
post #9 of 9 Old 07-08-2010
My Universal M25XP is set up with a bleeder valve at the end of the fuel injector spillover tubes that just bleeds the whole system back to the tank, just turn on the key open the bleed valve and the lift pump will purge the whole system while you go for a swim, make Margaritas and just relax! Just shut off the valve start the engine and off you go. I think this is stock on this engine because the valve was painted engine color.
anemoneii is offline
Dr. Diesel, Foley Engines, and me... skipgundlach Diesel 43 04-28-2016 04:16 PM
Diesel Fuel Essentials Tom Wood Gear and Maintenance Articles 0 03-22-2004 07:00 PM
Diesel Fuel Essentials Tom Wood Her Sailnet Articles 0 03-22-2004 07:00 PM
Gas versus Diesel Tom Wood Gear and Maintenance Articles 0 01-10-2002 07:00 PM
The Diesel Generator Mark Matthews Gear and Maintenance Articles 0 03-25-2001 07:00 PM
