What's up with my engine? (need 1000 words for my picture) - Page 2 - SailNet Community
Chat
Advertise Here
Go Back   SailNet Community > On Board > Gear & Maintenance > Engines > Diesel
Old 06-28-2010
bljones's Avatar
bljones has a spectacular aura about bljones has a spectacular aura about
Nope. Consistent BLACK smoke is an issue. White smoke is not a big deal, if she still starts easily and runs to full power. If you have trouble starting her (ie if you need to crank it for more than 30 seconds,) then you have a problem worth looking into.
Reply With Quote Quick reply to this message Share with Facebook
  #12
Old 06-28-2010
patrickstickler's Avatar
Rhumbunctious
patrickstickler is on a distinguished road
OK. It starts fine, runs fine, oil level good after the trip, etc. so I'm presuming/hoping then that it's just due to the extended usage, and will work on cleaning up the transom and keep an eye on it.
Thanks to everyone for the valuable input!
If a man speaks at sea where there is no woman to hear, is he still wrong?
Cruising the Baltic in 'Merihiisi', a 1979 Westerly Berwick Ketch
  #13
Old 06-28-2010
I think BLJ has nailed it... you were motoring for an awfully long period of time.
óCpt. Mal Reynolds, Serenity (edited)
StillóDON'T READ THAT POST AGAIN.
  #14
Old 07-01-2010
boatrips is on a distinguished road
Cleaning off your transom easily
The black diesel smudge on your transom is very easily cleaned off using, believe it or not, Gasolene, then with soap and water.
This is normal exhaust and there is nothing wrong with your diesel engine, just enjoy it as it is.
Fair winds and following seas,
Jim
  #15
Old 07-01-2010
SteveInMD is on a distinguished road
No you haven't blown a head gasket. The cause of black smoke (or excess soot) is too much fuel vs air in the combustion chamber. A small amount of soot in normal. Yours looks to me to be maybe a bit more than normal.
There can be many causes, but common ones are are excessive load on the engine from a dirty prop, dirty bottom, rope around the prop or shaft, clogged exhaust system, and the wrong size or too much pitch in the prop. It could be a clogged air intake system, but this is unlikely.
You may post attachments
You may edit your posts
Problem with PS 37 engine mounts waypt1 Pacific Seacraft 7 08-16-2010 02:53 PM
Runaway Diesel Engine Ben Hilke Gear and Maintenance Articles 0 07-19-2004 09:00 PM
Surveying a Diesel Engine Tom Wood Buying a Boat Articles 0 01-26-2003 08:00 PM
Surveying a Diesel Engine Tom Wood Gear and Maintenance Articles 0 01-26-2003 08:00 PM
Replacing the Diesel Engine Sue & Larry Gear and Maintenance Articles 0 06-12-2000 09:00 PM
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
SEO by vBSEO 3.6.1
The SailNet.com store is owned and operated by a company independent of the SailNet.com forum. You are now leaving the SailNet forum. Click OK to continue or Cancel to return to the SailNet forum.
