What's up with my engine? (need 1000 words for my picture) - SailNet Community
post #1 of 15 Old 06-26-2010 Thread Starter
Rhumbunctious
patrickstickler's Avatar
OK, so I've just bought an old boat with a 1979 Volvo Penta MD11C engine, rebuilt in 2001 with approx. 250 hours on it when I bought it, and now around 350 hours after bringing her home.
This is my first diesel engine, so as far as the engine is concerned, I'm a complete newb.
Stern was clean when I left, and I had the engine professionally serviced (oil change, oil filter change, all other fluids, fuel filters, and impeller checked, all OK).
Trip was 725 naut. miles, the full length of the Baltic. Sailed about 1/2 of the way and motored the last 1/2 or so when the wind died completely.
The engine performed flawlessly. I ran about 2000 rpm which pushed the boat along at around 5-5.5 knots. Temp remained good entire time. Plenty of water coming out of the exhaust. Nothing to suggest anything amiss.
But upon arrival, the stern exhaust port looks like this (see photo).
So... what's up with my engine? Should the exhaust port be that dirty?
If a man speaks at sea where there is no woman to hear, is he still wrong?
Cruising the Baltic in 'Merihiisi', a 1979 Westerly Berwick Ketch
patrickstickler is offline
post #2 of 15 Old 06-26-2010
One of None
deniseO30's Avatar
welcome to the smudge on the transom club! Not many boats don't get some kind of smudge if the exhaust is out the transom.
My last project!
deniseO30 is offline
post #3 of 15 Old 06-26-2010
T37Chef's Avatar
I don't see nuttin?
The yellow stain is not something I've seen, and the black looks pretty dark...but how was the exhaust when it was running? Clear, blue, black, white?
Shawn
T37Chef is offline
post #4 of 15 Old 06-26-2010 Thread Starter
Rhumbunctious
Originally Posted by T37Chef View Post
I don't see nuttin?
White to clear. Whiter when at higher RPMs.
post #5 of 15 Old 06-27-2010
Try removing it with MaryKate Easy On & Off Gel, and then see what happens. The black is soot more likely than not, and that is pretty common if the engine is running too rich or under a heavy load.
What is the WOT RPM on this, and what is the redline on the engine?
If the prop is sized wrong, you could easily have this happen.
Also, what is the LOA and LWL of the boat??
sailingdog is offline
post #6 of 15 Old 06-27-2010 Thread Starter
Rhumbunctious
The max RPM per the manual is 2500 and I was running around 1800 - 2000 most of the trip.
The boat is a Westerly Berwick Ketch. LOA 31 feet. LWL 25 feet.
Prop appears to be original, and thus used on the boat with this engine for 30 years. Presume it's the right size.
post #7 of 15 Old 06-27-2010
On the hard
CharlieCobra's Avatar
I'm wondering if the white is some oil that got into the system. You folks have seen machine shop milk right? It's a mixture of oil and water and would leave a stain a lot like that.
Baggett and Sons Marine Restoration
The Landing at Colony Wharf
Bellingham, WA.
CharlieCobra is offline
post #8 of 15 Old 06-27-2010
MARC2012's Avatar
You might have just blown out the built up carbon.
MARC2012 is offline
post #9 of 15 Old 06-27-2010
bljones's Avatar
Some soot is normal, a LOT of soot is something to think about. Having said that, consider that you in 9 years the engine has run roughly 28 hours per year... and you made the engine do roughly four years of her usual effort in one trip. Chances are she is gonna let you know she isn't happy with the change in routine.... IF she isn't happy.
Did she buck, sputter, whine, spit, complain, refuse to start, or otherwise let you know she is no longer interested in hanging out with you?
Let me clarify: The ENGINE, not your WIFE.
If the answer to the above is "no", and you didn't notice any serious white smoke (diesel smoke is like marijuana: a whiff is okay, but when you start hacking and coughing and can't see for the smoke, you have a problem), then I would not be too worried.
bljones is offline
post #10 of 15 Old 06-27-2010 Thread Starter
Rhumbunctious
Nope. Purred like a kitten the whole way.
There was some white smoke, more during the end of the trip than the beginning. Does that mean I've blown a head gasket or something?
Problem with PS 37 engine mounts waypt1 Pacific Seacraft 7 08-16-2010 01:53 PM
Runaway Diesel Engine Ben Hilke Gear and Maintenance Articles 0 07-19-2004 08:00 PM
Surveying a Diesel Engine Tom Wood Buying a Boat Articles 0 01-26-2003 07:00 PM
Surveying a Diesel Engine Tom Wood Gear and Maintenance Articles 0 01-26-2003 07:00 PM
Replacing the Diesel Engine Sue & Larry Gear and Maintenance Articles 0 06-12-2000 08:00 PM
