Anyone ever disassemble a cylinder head? - Page 2 - SailNet Community
post #11 of 13 Old 07-10-2010
priscilla's Avatar
Go to Westerbeke.com and down load the Universal 25xp service manual, its free!
Priscilla
priscilla is offline
post #12 of 13 Old 07-10-2010
When you get the manual, you will also find that the studs/bolts used to attach the head may or may not be reused--do not reuse them unless the manual say to, because some bolts are designed to distort when torqued down, and be thrown out after one use.
Your friend has a torque wrench of course, so he also knows that the cylinder head bolts need to be REtorqued, typically a month or so after the head was installed. The manual will have a more specific figure based on hours of operation.
The job isn't brain surgery--but there are many small mistakes that can be made which will easily ruin it. Pretty much any shop manual (see your local library) will at least cover most of the procedures, they're all substantially similar.
hellosailor is offline
post #13 of 13 Old 07-11-2010
Capnblu's Avatar
How did you determine you needed to replace the head gasket?
Why, why, why?
I Don't Know! I Don't Know!
Capnblu is offline
Cylinder head for yanmar sb 12 RepDom Gear & Maintenance 4 06-14-2010 03:46 PM
Head Location? jbarros Sailboat Design and Construction 9 03-18-2010 09:41 PM
Updating Your Head Sue & Larry Gear and Maintenance Articles 0 12-25-2002 07:00 PM
Head Maintenance Blues Tom Wood Gear and Maintenance Articles 0 11-21-1999 07:00 PM
Head Maintenance Blues Tom Wood Her Sailnet Articles 0 11-21-1999 07:00 PM
