Help! Leaking Injector Pump - Page 2 - SailNet Community
post #11 of 88 Old 07-29-2010
tdw
Super Fuzzy Moderator
tdw's Avatar
Mate if the mechanic is coming down anyway leave it alone. All you can probably do right now is make it worse.
Andrew B (Malö 39 Classic)
― Terry Pratchett.
tdw is online now
post #12 of 88 Old 07-29-2010
are you sure theres a gasket?,usually there's just precision shim/shims,btw from the pix it looks to have been leaking for some time,if you do remove the retainer be sure to replace with the exact same thickness shims and torque
sawingknots is offline
post #13 of 88 Old 07-29-2010 Thread Starter
Once known as Hartley18
Classic30's Avatar
Dock
No, I'm not sure there's a gasket. There's nothing specifically stated in the Workshop Manual, but there must be something there to keep the fuel in... and yes, I suspect it's been leaking for a while, filling the bilges with diesel at $1.30 a litre..
As I mentioned in the first post, I'm mechanically-illiterate. That's one reason I called the mechanic when it looked like there was more than just brute force required to fix this.
I was hoping that someone here may have come across this before. I have no idea how an injection pump works - and the Workshop Manual seems to indicate "if it needs fixing, remove the whole thing and return it to Volvo for repair.."!!!
Classic30 is offline
post #14 of 88 Old 07-30-2010
an injection pump is precisely machined so much that a gasket isn't necessary,a gasket wouldn't be able to withstand the enormous pressure also it wouldn't be conducive to the critical clearance required,your right to repair this sooner than later because the leak will only get worse and eventually damage the the pump mating surface.
post #15 of 88 Old 08-01-2010 Thread Starter
Classic30's Avatar
Dock
What you are saying makes sense - except that I don't see how shoving a shim between the "precisely machined mating surfaces" (as per the Manual) won't cause a leak!
The mechanc is supposed to be coming down to "have a look after lunch". These are the people who put the engine in, so they should (hopefuly) know what they're doing..
post #16 of 88 Old 08-01-2010 Thread Starter
Classic30's Avatar
Dock
'kay.. that was a waste of time. The apprentice showed up and said his Dad is on holidays in Bali and won't get back till next week.
After scraping away some of the flaking paint it does seem that the leak is coming from underneath 2 of the 3 "faceplates" that hold the injector pipes onto the body of the pump - trouble is, you need a special 5-pointed wrench to undo them.
The workshop manual says "Send the pump to Bosch if the workshop does not have specially trained personnel with the necessary testing equipment".
But this engine wasn't made yesterday. It sounds like I'm totally stuffed this time..
Anyone got any other ideas??
post #17 of 88 Old 08-01-2010
Handsome devil
Stillraining's Avatar
My guess is a leaking Quill shaft.... but I have kept quite till now...it needs rebuilt by a qualified shop as said by others...about 500.00 US
"Go Simple...Go Large"
Relationships are everything to me..everything else in life are just tools to enhance them.
The purchase price of a boat is just the admittance fee to the dance...you still have to spend money on the girl...so court one with something going for her with pleasing and desirable character traits others desire as well... or you could find yourself in a disillusioned relationship contemplating an expensive divorce.
Stillraining is offline
post #18 of 88 Old 08-01-2010
its hard to see[from your pix]what special wrench/bolt your referring to,is it a female hex bolt?is your special bolt,number 22? file:///C:/Documents%20and%20Settings/Owner/Desktop/volvo-penta-explodedview-7746800-23-182.aspx.htm
post #19 of 88 Old 08-01-2010
there appears to be a o ring under the locking plate
post #20 of 88 Old 08-02-2010
considering your situation i woulds advise you to wait on a competant mechanic,good luck
