High oil pressure - SailNet Community
post #1 of 7 Old 08-09-2010 Thread Starter
High oil pressure
2qm15 Rwc Engine.
I Am A New Owner To This Boat. The Oil Pressure Is About 75psi And Only Drops Slightly When Warm. Specs Are About 42psi.
I Put A Manual Gauge Then Replaced The Oil Sending Unit And Both Are Similar.
Is This A Problem?
Thank You
Kevin
kegendron is offline
post #2 of 7 Old 08-09-2010
Freedom 39
FarCry's Avatar
That sounds pretty high. My QM15 goes up to about 75 when it first starts, once warm it drops to about 50. Does your oil pressure vary with the RPM or is it constant? If everything is running fine and not leaking oil I probably would just do an oil change and make sure you put the proper weight oil back in and see what it does.
FarCry is offline
post #3 of 7 Old 08-09-2010
mitiempo's Avatar
And be careful not to put too much oil in.
Brian
mitiempo is offline
post #4 of 7 Old 08-09-2010
poopdeckpappy's Avatar
Is your new sending unit compatible with your old gauge and is the new sender a single sending unit and not dual
1955 Blanchard 51 Custom ( I got a woody )
1974 Ranger 33
Friends don't let friends do stupid things alone
poopdeckpappy is offline
post #5 of 7 Old 08-09-2010 Thread Starter
High Oil Pressure
My Oil Gauge Is 0 - 80 And The Sending Unit Is 0- 100.
But I Did Put A Mechanical Gauge On The Block And It Is Reading About The Same.
How Can I Match Up A Gauge And A Sending Unit Properly?
Thanks
post #6 of 7 Old 08-10-2010
Tell your marine exchange which gauge(s) you have and they'll be able to tell you what is compatible; I'm pretty sure that SW & Teleflex use the same sender ( ie: teleflex and Sierra senders) and a VDO will not work. I'm also pretty sure if you have a 0-80 gauge you'll need a 0-80 sender, also make sure it's a single station sender, unless you have a low pressure shut off on the engine in addition to a OP gauge or gauges in two locations.
1974 Ranger 33
post #7 of 7 Old 08-10-2010
Something else you could look into is the pressure relief valve ( it's should be close to the oil pump ) if it's stuck closed it will show a high reading, but I would look there last, unless you're oozing oil
1974 Ranger 33
Pressure Washers TakeFive Gear & Maintenance 29 08-20-2011 11:36 PM
Recommended Oil for Yanmar 2GM20F ccvalentino Diesel 4 08-01-2010 04:49 PM
