Kudos to Racor - SailNet Community
Chat
Advertise Here
Go Back   SailNet Community > On Board > Gear & Maintenance > Engines > Diesel
Old 08-17-2010
bron is on a distinguished road
Kudos to Racor
Kudos to Racor - Parker Hannifin. The drain valve to my 30 year old diesel filter and water separator cracked and was leaking fuel into the bilge. After scouring the local suppliers for a replacement I was resigned to buying a new filter ($100 to $150). As a last resort I called Racor to try to find a supplier. Although they haven't made the filter for many years, they immediately identified the filter and knew a current model had the same drain. Best of all they said they would send me one. It arrived three days later. NOW THAT'S SERVICE. Thirty years later they still back their product. Stick with Racor folks. Not some cheap offshore knock-off.
Reply With Quote Quick reply to this message Share with Facebook
You may post attachments
You may edit your posts
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
SEO by vBSEO 3.6.1
The SailNet.com store is owned and operated by a company independent of the SailNet.com forum. You are now leaving the SailNet forum. Click OK to continue or Cancel to return to the SailNet forum.
