Universal Atomic 3 Diesel alternator - SailNet Community
post #1 of 25 Old 08-29-2010 Thread Starter
Newest of newbies thanks. Previous owner told me that the motor is a universal atomic 3 diesel. I a, confidant that it is a diesel and a 3. All kinds of problems already. The motor was running but not charging. Previous owner said he would take a look at it. He took the alternator off found out it was bad and i don't think i am seeing it again.(core charge) So now i am left with the motor and no part number to order a new alternator. Any help would be very much appreciated and if you know the part numbers for fuel and oil filters for this engine that would be great also.
Thank you.
fly2greenroom is offline
post #2 of 25 Old 08-29-2010
TQA
Bombay Explorer 44
TQA's Avatar
Re the alternator any alternator that will allow you to line up the pulley correctly +- 2 mm will do. Take measurements and head to NAPA.
Before you go see if you have an external regulator for it. They will want to know that.
TQA is offline
post #3 of 25 Old 08-29-2010
That's a very common engine.. a quick tour around your marina should turn up a few examples, I'd just ask around and get some data from them.
In addition to pulley alignment you'll have to be sure there's going to be clearance for the new alternator inside the compartment, and also that there's room to accommodate the length of the alternator alongside the engine.
btw these engines are mostly referred to as Universal Diesels - the Atomic label was only attached to the early versions.
Faster is offline
post #4 of 25 Old 08-29-2010
Irrationally Exuberant
I don't know anything about Universal Diesels--though I thought I had read that Universal didn't make the diesels with their name on it, only the gas engines. Maybe Westerbeke?
There is some information out there:
An Owners Manual
http://www.ewmanchester.com/CalDocs/...s%20Manual.pdf
And this looks interesting:
westerbeke, marine generators, engines, Official Site
Tom K
2000 Beneteau 331
Northern Chesapeake Bay
arf145 is offline
post #5 of 25 Old 08-29-2010
The Universal Diesels are basically marinized Kubota tractor engines. While it's doubtful that the tractors would have a high enough output alternator, there's another place to start looking.
Faster is offline
post #6 of 25 Old 08-29-2010
One of None
deniseO30's Avatar
I asked the same question a while back.
Maine Sail (one of the members here) suggests this place.
Spider Marine Electric Supply, Inc.
My last project!
deniseO30 is offline
post #7 of 25 Old 08-29-2010
One of None
deniseO30's Avatar
that a wooden boat you have there Fly?
My last project!
post #8 of 25 Old 08-29-2010 Thread Starter
Thanks for all of the replies yes it is a wooden boat so i have my work cutout for me. Lapworth 40 older than me and i am not that young. I will measure it the best i can i know that the alternator that came out of there was only 30 amp so i think i want something bigger any sugestions?
post #9 of 25 Old 08-29-2010 Thread Starter
...btw these engines are mostly referred to as Universal Diesels - the Atomic label was only attached to the early versions.
This one would be very early.
Thanks
post #10 of 25 Old 08-29-2010 Thread Starter
Yes wooden.
Is this Diesel Yamaha actually a Yanmar? peterxr600 Diesel 10 11-07-2012 09:47 PM
Universal Engine Rebuilder in PA tbirg Diesel 2 08-28-2010 11:23 PM
Seattle (Bellevue/Renton) Atomic 4 rebuilding SeattleIanReilly Atomic 4 5 08-12-2010 12:16 AM
Inverter issue (maybe alternator based) contagous Gear & Maintenance 17 08-04-2010 07:03 PM
