Cleaning out fuel tank - SailNet Community
post #1 of 17 Old 09-03-2010 Thread Starter
Arf!
pegasus1457's Avatar
My primary fuel filter recently clogged after less than 10 gals of diesel fuel passed through it, making me suspicious of the state of the fuel tank.
I have been scrupulous about where I buy my fuel, keeping the tank topped up, especially during the winter layup, and adding biocide with each fuel addition. But the POs of this boat may not (this is a charitable view of the POs ) have been so careful, so who knows what crud is at the bottom of the tank.
Is there a way to clean a diesel tank without removing it? I would REALLY like to avoid removing it. It is a real PITA job.
Thanks for any suggestions.
Fluctuat nec mergitur
pegasus1457 is offline
post #2 of 17 Old 09-03-2010
Warm Weather Sailor
Vasco's Avatar
Yes, look up "fuel polishing" in your area. They will come and pump your fuel through a few filters and squirt it back into your tank, cleaning it all over until it's clean.
Rick I
Toronto in summer, Bahamas in winter.
Vasco is offline
post #3 of 17 Old 09-03-2010
Unfortunately, fuel polishing will only get rid of the stuff floating in the fuel. It generally won't get the stuff that is adhered/growing on the sides of the tank. It is often that stuff that dies off or gets shaken loose in heavy weather and causes the fuel problems. Steam cleaning the tank is really the best idea if you've got fuel contamination issues.
sailingdog is offline
post #4 of 17 Old 09-03-2010
If you have inspection ports on the tanks and physical access, you can also empty the tank, remove the ports, and scrub it by hand.
Get it as clean as you possibly can, THEN do the fuel polishing thing. Properly done, fuel polishing nozzles are moved around the tank, squirting fuel on the tank walls during the polishing process. This helps to clean the tank walls, as diesel fuel itself is a fairly decent cleanser.
Thereafter, the biocide or other additive is a good idea, but the real solution is to install a fuel polishing system integral to the boat. Not hard to do, and it makes light work of keeping the fuel clean.
Bill
btrayfors is offline
post #5 of 17 Old 09-03-2010
One of None
deniseO30's Avatar
If it's an old tank all the money you spend on polishing, filters, and more it would be cheaper to change out the tank. (imho) REALLY! Been there done that! After agonizing over my tank that had pinholes weeping it came out in less then a hour! The new one is smaller and I can actually remove it myself without help now. 20mins.
My last project!
deniseO30 is offline
post #6 of 17 Old 09-03-2010 Thread Starter
Arf!
steam cleaning
Can steam cleaning be done with the tank on the boat?
What access is required to the inside of the tank? There are no inspection ports on my tank. Just the fill, the two connections to/from the engine, the gauge, and the vent.
post #7 of 17 Old 09-03-2010
It depends on the access to the tank, and whether the tank is baffled or not. Most tanks don't have decent access/inspection ports, and they should have them added IMHO.
post #8 of 17 Old 09-03-2010
I have to agree w/Denice, after 30 years, you probably have some major issues. Hard to find pin holes. Stainless doesn't last forever.
sailor50 is offline
post #9 of 17 Old 09-03-2010
One of None
deniseO30's Avatar
most of those older tanks were aluminum I think.. mine was. thank you Sailor 50. I just don't understand how strongly people think they can "save" old tanks. New, off the shelf tanks are really quite cheap
My last project!
post #10 of 17 Old 09-03-2010
You are right Denise, most of the tanks were made from aluminum, much less noble than stainless. We had a new one custom made out of stainless. When we pulled the old aluminum one out - it looked like swiss cheese! We can now visibly see the tank as we relocated it to a better site.
sailor50 is offline
Yanmar fuel/ power problems snowdawg Diesel 13 12-04-2013 11:22 PM
Holding Tank Vent tdw Gear & Maintenance 21 09-02-2010 09:32 PM
Virtual Fresh Water Tank mbettman Gear & Maintenance 10 08-31-2010 04:52 PM
Two fuel pumps-A4 QuickMick Gear & Maintenance 2 08-22-2010 05:07 PM
Emergency fuel supply ffiill Diesel 6 08-12-2010 06:12 PM
