Universal Diesel M25 - SailNet Community
 1Likes
  • 1 Post By sailingdog
post #1 of 4 Old 09-16-2010 Thread Starter
I have a C30 with a M 25 motor can I safely run it for a short time while it is out of the water. It has a fresh water expansion tank that is cooled through a heat exchanger.
Walt352 is offline
post #2 of 4 Old 09-16-2010
mitiempo's Avatar
Yes. if you take the hose off the raw water seacock and place it in a bucket of water. Not in gear for very long though as the cutlass depends on water for cooling.
Brian
mitiempo is offline
post #3 of 4 Old 09-16-2010
If you need to run it for longer, but not in gear, you can put a hose in that same bucket, so that the engine doesn't run out of water. DO NOT CONNECT THE HOSE DIRECTLY TO THE ENGINE... that is a really, really bad idea.
H W. Smith likes this.
sailingdog is offline
post #4 of 4 Old 09-16-2010
One of None
deniseO30's Avatar
It also would not be a good idea to put it in gear and use the prop as a fan when your working under the boat and it's hot outside.
My last project!
deniseO30 is offline
Oil pan for Universal Diesel upnatit Gear & Maintenance 22 05-13-2015 08:05 AM
Universal diesel Kobuta oil filter is a Fram PH3593A looking for diesel fuel filter dave hirsh Diesel 4 06-07-2010 09:01 AM
Universal 11 Diesel Engine grinfax Gear & Maintenance 3 08-05-2008 08:31 PM
Universal Diesel Substitute duffer1960 Gear & Maintenance 5 05-31-2008 11:36 AM
Universal diesel 5411 rmiille Gear & Maintenance 1 12-30-2001 06:01 AM
