engine starts but won't shut off - SailNet Community
post #1 of 9 Old 09-16-2010 Thread Starter
engine cuts on but not off
i have a morgan o/i 28 and the ignition switch is new and wired properly...engine cuts on but does turn off...couldnt find a off switch anywhere...had to turn the valve off on the feul line to let the lines run out...help please
jamesgmahoney3 is offline
post #2 of 9 Old 09-16-2010
More information will be helpful. i.e. what engine,what year vessel etc.
Many diesels have a separate cut off switch or lever that kills the fuel flow to stop the engine. Look for a pull cable (like the old choke on cars) near the engine panel, or look for the other end at the injection pump.
But let other Morgan owners know what you've got and I'm sure a specific answer will be forthcoming.
Faster is offline
post #3 of 9 Old 09-16-2010
JimsCAL's Avatar
Diesels stop by cutting off the fuel - some have a fuel cutoff handle and some you just move the trottle past idle. The ignition switch will not stop the engine, just turn off the instrumentation.
JimsCAL is offline
post #4 of 9 Old 09-16-2010
jackdale's Avatar
Turning off the ignition switch on some boats will blow the diodes in the alternator.
You must cut off the fuel.
jackdale is offline
post #5 of 9 Old 09-16-2010
Most often true but not always.. our engine - the ignition switch also kills a solenoid shutoff on the fuel at the injection pump.
Faster is offline
post #6 of 9 Old 09-17-2010
islander bahama 24
newhaul's Avatar
hello i am a marine mechanic and as others have stated we need to know what engine you have. is there an electrical wire on the injection pump if so that is the fuel solinoid and shutting off the power to it will stop engine. otherwise its a pull cable.
newhaul is offline
post #7 of 9 Old 09-17-2010
davidpm's Avatar
Except on the Yanmar YSE8 that apparently shuts off by moving the throttle past idle.
davidpm is offline
post #8 of 9 Old 09-17-2010
islander bahama 24
newhaul's Avatar
it is the same with my bmw d12 which means that your yanmar is mechanical injection shutoff not electrical but all this is moot untill we know what engine he has in his sv.
newhaul is offline
post #9 of 9 Old 09-20-2010
Usually not. Turning the battery switch to off can destroy the diodes, but turning the key off should be no problem.
SteveInMD is offline
Help-Yanmar Diesel Shut off PalmettoPirate Diesel 6 10-20-2009 11:14 AM
Necessary to shut off raw water intake? harpguitar Gear & Maintenance 9 08-09-2008 01:54 PM
C270 shut down. tagster Gear & Maintenance 5 05-07-2007 04:17 PM
Batteries for brisk engine starts. jr438234606 Gear & Maintenance 6 10-26-2006 06:24 PM
