Yanmar 2qm20 oil out breather - SailNet Community
post #1 of 5 Old 09-20-2010 Thread Starter
Hi I have a Yanmar 2qm20 motor and have been using it for about 4 years now. Lately, after starting the motor, after a few seconds oil will start squirting out of the breather which is located just above the fuel injection pump. The motor sounds normal yet oil is being squirted all over the engine room. Could anyone tell me what the problem is and what would be possible solutions? Do I have to haul the motor out of the boat for repairs? Would be immensely grateful for any info...
Gerrit747 is offline
post #2 of 5 Old 09-20-2010
There's probably a crankcase vent hose that runs from the valve cover to the breather. Try pulling that off the breather cannister and see if that's the source of your oil.
Typically the engine is meant to suck in these fumes along with combustion air, and it eventually all goes out the exhaust.. engines with failing rings can develop "blowby" which tends to pressurize the crankcase and may lead to excess oil getting to the breather...
That said, I'm not real familiar with that engine so I, too, could be blowing smoke!!
Faster is online now
post #3 of 5 Old 09-20-2010
On the hard
CharlieCobra's Avatar
Sounds like blowby to me as well.
Baggett and Sons Marine Restoration
The Landing at Colony Wharf
Bellingham, WA.
CharlieCobra is offline
post #4 of 5 Old 09-24-2010 Thread Starter
Thanks very much, your advice has put me on the right track. Motor to be taken out on next hard standing... I shall certainly frequent this forum more...
post #5 of 5 Old 09-24-2010
You might want to get a mechanic to do a compression test before pulling the engine. If it is blow by the engine will have low compression which means rings. The engines are easily rebuildable. I have a Yanmar tractor with virtually the same engine. I rebuilt it myself for about $1,000. These engines are virtually industructable. My Endeavour has the same engine.
Endeavour 32
bfloyd825 is offline
Low hours on Yanmar 2QM20 zaldog Gear & Maintenance 19 10-01-2013 07:12 PM
Yanmar 2QM20 Exhaust part - help hertfordnc Gear & Maintenance 19 12-13-2010 06:07 PM
Diesel Engine Replacement - Yanmar 2QM20 westannapoliscrew Diesel 0 03-30-2010 04:45 AM
Will a yanmar 2QM20 fit in a Catalina30? HermitScott Gear & Maintenance 10 09-21-2009 02:30 AM
Yanmar 2QM20 tranmission- substitutions? hertfordnc Gear & Maintenance 1 01-19-2009 05:29 AM
