Exhausting a diesel generator - SailNet Community
post #1 of 3 Old 09-23-2010 Thread Starter
Hello. I wonder if anyone has ever ran an exhaust system from the muffler of a portable generator through the hull to make it semi fixed.
I have a portable diesel generator that works well and a great spot where the boat manufacturer mounts the factor genset. I can ventilate it well but have to work out how to run the engine exhaust.
The exhaust is currently a 35mm small pipe dry system.
I was thinking of extending the pipe and then clamping exhaust hose to it. Maybe even making a wet system by pumping water into it. Although if I could keep it dry it would be better.
Anyone done something like this?
Thanks
Dean
deandavis1 is offline
post #2 of 3 Old 09-23-2010
Mermaid Hunter
SVAuspicious's Avatar
Be careful about exhaust temperature on a dry system. You could melt the gel coat.
SVAuspicious is offline
post #3 of 3 Old 09-23-2010 Thread Starter
Thanks I will test in on land before installing anything. I have also been looking for diy instructions for a wet exhaust but not found much.
I read with interest someone mention just pumping water through a sleeve. Sounded like a good idea to keep water well away from entering the genset.
Help costing a generator and lots of generator questions... labatt Gear & Maintenance 10 10-16-2008 01:01 AM
"portable" diesel generator for $1899 dohenyboy Gear & Maintenance 4 08-12-2007 09:38 AM
Auto Diesel vs Marine Diesel / Addatives NewsReader Mass Bay Sailors 0 07-11-2007 06:15 PM
Ultra low sulphur diesel and the older marine diesel Valiente Gear & Maintenance 2 10-20-2006 12:10 PM
The Diesel Generator Mark Matthews Gear and Maintenance Articles 0 03-25-2001 07:00 PM
