Oil drain on Universal M4-30 - SailNet Community
post #1 of 5 Old 10-09-2010 Thread Starter
Arf!
pegasus1457's Avatar
My M4-30 has an oil drain hose attached to the bottom of the crankcase.
There is a threaded plug at the outlet end of this hose. When I unscrew the plug and insert my sucker hose, I don't get anything out of it.
I can see that the attachment point for this hose has a thin hex nut on it. I am guessing this is a valve. The engine owner's manual is no help.
But I would like to hear from someone who knows, since if I am wrong I will have to deal with 4 quarts of dirty oil in the bilge.
Thanks for any help on this one...
Fluctuat nec mergitur
pegasus1457 is offline
post #2 of 5 Old 10-09-2010
Question
That hose, formerly an option on Universals, is nowadays standard.
Our '88 had the option. It always worked but seeped some oil around the hose connection, so several years ago I replaced the hose on the "banjo fitting." I had to source a new pair of composite flat washers for the banjo too, as I recall.
If you put your sucker hose clear to the bottom where it would meet up with the machined 90 turn inside that banjo fitting, and you push it down hard, it could easily make a seal against the inside of the machined metal fitting and you would not be able get the oil out.
You might try pushing the oil suction tube down as far as reasonable and then pulling it back about an inch or so. Should start picking up oil with no problem. If not, then it's probably time to take the fitting off, mess and all, and refurbish that system. Of course this will involve getting an end wrench under a place you can not view without a mirror!
(One of those "bore o scope" gadgets might be a help...)
Good luck!
L
olson34 is offline
post #3 of 5 Old 10-09-2010
Maine Sail's Avatar
If the insertion hose is sucking air wrap the joint where it enters the drain hose with electricians tape to make it air tight. Don't forget to remove the oil cap and warm the oil before trying to suck it out..
______
-Maine Sail / CS-36T
Maine Sail is offline
post #4 of 5 Old 10-09-2010
Originally Posted by pegasus1457 View Post
....I can see that the attachment point for this hose has a thin hex nut on it. I am guessing this is a valve.....
I'd be surprised if that's a valve... it's likely just the bushing for the original plug.
Sounds like the hose is plugged somehow if you can't pull out the oil.. as MS says make sure it's warm.
Faster is offline
post #5 of 5 Old 10-09-2010 Thread Starter
Arf!
Good point, Maine (as usual). The oil was warm, but I had not yet opened the fill cap. I was not sucking air, just nothing moved.
In the end I stuck my sucker hose down the dipstick hole and got the job done -- after opening the fill cap.
Next time I will open the fill cap and try the drain hose again. [The dipstick on this engine is located at the most impossible place imaginable. Its location might have made sense when this engine was on a tractor. I find its hole by the Braille method, but only because I had previously taken photos from behind the engine with the dipstick inserted.]
Thanks.
mac 25 cockpit drain. jhnblngr MacGregor 4 06-18-2009 12:00 AM
Ack! What did I drain? edstill Gear & Maintenance 5 03-30-2009 07:13 PM
ice box drain exfus55 Sailboat Design and Construction 18 08-26-2008 02:32 PM
Oil Drain Universal M18 MBesant Gear & Maintenance 3 07-12-2006 07:40 AM
Universal m35 leak at drain plug sailingdeacon Gear & Maintenance 1 01-07-2005 11:21 AM
