No oil pressure after oil change - SailNet Community
post #1 of 31 Old 10-11-2010 Thread Starter
Have a strange issue with my M25XPB. First of all, the boat/engine are new to me and the boat has sat in dry storage for about two years. I had the diesel tank cleaned out and filled with fresh diesel, put on a new Racor etc and the engine fired up and ran perfectly. Oil pressure was between 50-60 psi when I was warming it up. I then changed the oil and filter, checked the oil level and fired it back up. The alarm never shut off and the oil pressure gauge was reading 0 psi. I shut the engine down and checked the oil and the level was fine. I then tested the switch by grounding and it seems to be fine. To rule out the sender, I fired it up again and tested with a mechanical gauge. It was reading a little less than 5 psi with the mechanical gauge. I pulled the hose that goes from the block (above the filter) to the sender switch fitting and cranked the engine over a few times and it seems that no oil is pumping through that hole (the one in the block above the filter). There was oil in the new filter when checked, so it seems that oil is getting from the pump to filter.
I find it very odd that this happened so suddenly. What could be blocking oil flow between the filter and the sender (and rest of the engine)?
brob76 is offline
post #2 of 31 Old 10-11-2010
First thought.... did you get the correct filter? Five PSI is definitely low and I wouldn't run the engine long without fixing this.
Worst case scenario is that your lube pump has failed, but that's pretty rare.. mind you that pump probably won't like trying to pump against a dead head either, so if something did block the pump discharge it may now be damaged.. but hopefully it's not as dire as that....
Faster is offline
post #3 of 31 Old 10-11-2010 Thread Starter
I did get the recommended filter but it was different than the one the PO had on it. They look almost identical. It does look like oil is getting pumped into the filter...just not getting past there for some reason. Very odd that is happened suddenly after an oil change.
brob76 is offline
post #4 of 31 Old 10-12-2010
Liquorice's Avatar
get a new filter!
not the same one you have now, but a crossed matched from a different manufacturer. some filters have none return valves in them and may not be right for your engine.
For $10 it's worth a try.
Sam :-)
sam :-)
Just because you're paranoid ...doesn't mean they're not after you!
Liquorice is offline
post #5 of 31 Old 10-12-2010
Grasshopper
JiffyLube's Avatar
I vote for the correct filter too.
JiffyLube is offline
post #6 of 31 Old 10-12-2010
Cheapest thing to try at this point....
Faster is offline
post #7 of 31 Old 10-12-2010
Chastened
Ajax_MD's Avatar
If replacing the oil filter doesn't work, another possibility is that the oil pump has lost it's prime, and that there is an air bubble in the path.
The way to fix that, is to manually prime the oil pump by filling the oil filter full of oil and screwing it onto the engine, or by directly pouring some oil down into the screw fitting that the filter screws onto.
This has happened to me twice, on engines of different applications. It's rare, but it happens.
Alacrity, 1981 Tartan 33 #168
Ajax_MD is offline
post #8 of 31 Old 10-12-2010
美国华人, 帆船 教授及输送
10 x. This is a correct answer.
I doubt it is the new filter problem. All filters have a by-pass safety valve. And I doubt the oil pump fails suddenly. I assume that you replaced with the wt of oil, right.
I would like to hear the final verdict.
Fine Print:
I am old school. Integrity is to do the right thing even when no one is watching.
rockDAWG is offline
post #9 of 31 Old 10-12-2010
Grasshopper
JiffyLube's Avatar
Some filters are diesel specific because of pressure requirements, and I aways fill the new filter with oil before installing.
post #10 of 31 Old 10-12-2010 Thread Starter
Tried everything today. New filter from Napa same as the one that was working previously, filled the filter etc. Still almost no pressure (~2psi). If I disconnect the oulet line above the filter, oil does pump out when cranking. I'm at a loss. Not at all impressed with these Universal engines. Seems to be nothing but problems from what I've read and this experience.
brob76 is offline
Atomic 4 oil pressure gunnyret92 Atomic 4 8 08-19-2013 11:05 PM
Barometric Pressure sailortjk1 General Discussion (sailing related) 17 01-19-2007 08:01 AM
At sea. Volvo Ocean Race: Sanderson still leads but high pressure ridge good change everything @ BYM Sailing News NewsReader News Feeds 0 04-15-2006 08:16 AM
helm pressure Viking7 Racing 2 04-23-2005 05:53 PM
W60 - No oil pressure after oil change??? pma_foyl Gear & Maintenance 9 12-01-2004 09:45 AM
