Yanmar 3GMD transmission oil confusion in manuals - Page 2 - SailNet Community
 3Likes
post #11 of 33 Old 10-26-2010 Thread Starter
ATF is much thinner than any grade of engine oil. If you use ATF I would expect that the various bearing and wear surfaces are more subject to damage and premature failure. If ATF was required and you used engine oil, I suspect that the oil might not flow to all of the places with tight clearances and also cause premature wear.
mbsl98 is offline
post #12 of 33 Old 10-26-2010
"paint - nice thick stuff that seems to fill in engraved info nicely" Some automotive brake cleaner should clean that paint out very quickly. Or, some gel stripper left on for a while, following with a wire brush or "acid" brush (stiff plastic).
IIRC the 3H and 3G series use different transmissions so the same fluid might kill one or both. Dexron has been obsoleted, I think they are up to Dexron-IV by now. But using the wrong type of ATF fluid can ruin a transmission or the seals in it, so you'd want to make Real Damn Sure before adding anything to it.
hellosailor is offline
post #13 of 33 Old 05-29-2014
Re: Yanmar 3GMD transmission oil confusion in manuals
Asking again
Does anyone have a source for a definitive answer on the tranny oil (engine oil or Dexron)?
wrapper is offline
post #14 of 33 Old 05-29-2014
casey1999's Avatar
Originally Posted by wrapper View Post
Asking again
I think one of your previous posts says the tranny name plate says 20/30. This would be the weight of diesel engine oil. You DO NOT want to put in ATF oil into your transmission.
The yanmar manuals have many errors when calling out the transmission oil. I have a 3gmd also but with the v-drive Kansaki transmission. I used the same 40 weight oil in both the transmision and engine just to make life easy. The yanmar manuals are correct for engine oil but for transmission- follow the name plate data.
casey1999 is offline
The Following User Says Thank You to casey1999 For This Useful Post:
wrapper (05-29-2014)
post #15 of 33 Old 05-29-2014
Asking again?
Previous posts?
Come on, guys. This thread has been dead for nearly four years and wrapper has no previous posts in it.
You want a definitive answer? Ask Yanmar, and specify what transmission you're talking about.
Yanmar America Corporation
101 International Parkway
Adairsville, GA 30103
P 770.877.9894
F 770.877.9009
Or use the "Questions?" button on YANMAR | Yanmar North America
They're not so hard to contact. And they are, by definition, the sole definitive source of information on their products.
christian.hess likes this.
post #16 of 33 Old 05-30-2014
casey1999's Avatar
Here is a good link that tells what oil for what transmission:
http://www.sailnet.com/forums/diesel...-new-post.html
I see where a KBW10D can be mated to a Yanmar 3GMD and the trans calls for Dexron II/III ATF 24 ounces- so you need to see if you have a KBW 10D transmission.
(Note the # after oil type is volume in ounces)
Page:
Capacity Chart
Model Application(s) Fluid Type/ Ounces/ Rotation
KM2A 1GM/2GM/3GM SAE 30W /10 /Clockwise
KM2C 1GM10/2GM20 SAE 30W 10 Clockwise
KM2P 1GM10/2GM20/3GM30V SAE 30W 10 Clockwise
KM2P-1 2YM15/3YM20/3YM30 SAE 30W 10 Clockwise
KM3A 3GM/3GMF/3JH2 SAE 30W 15 Clockwise
KM3A-1 3JH2E SAE 30W 15 Clockwise
KM3A-2 3JH3E/4JH3E SAE 30W 15 Clockwise
KM3P 3GM30F SAE 30W 12 Clockwise
KM3P-1 3JH2E SAE 30W 12 Clockwise
KM3P-2 4JH2E SAE 30W 12 Clockwise
KM3P-3 3JH3 SAE 30W 12 Clockwise
KM3P-4 3JH3E/4JH3E SAE 30W 12 Clockwise
KM3V 1GM/2GM20/3GM30V SAE 30W 10 Clockwise
KM35A 3JH3/4JH3 SAE 30W 22 Clockwise
KM35A2 4JH4E SAE 30W 22 Clockwise
KM35P 3JH3/4JH3 SAE 30W 17 Clockwise
KM4A 4JH ALL/4JH2 ALL SAE 30W 44 Bi-Rotation
KM4A-1 3JH3E/4JH3E SAE 30W 44 Bi-Rotation
KM5A 4LH-TE/THE/DTE SAE 30W 71 Bi-Rotation
KMH4A 4JH3 TURBO SAE 30W 68 Bi-Rotation
KMH6A 6LY(A)-UTE SAE 30W 135 Bi-Rotation
KMH60A 6LYA/6LY2A-STP SAE 30W 135 Bi-Rotation
KMH61A 6LY3-ETP SAE 30W 135 Bi-Rotation
KBW10 2QM15 Dexron II/III ATF 24 Clockwise
KBW10A 2QM20H Dexron II/III ATF 24 Clockwise
KBW10B 2QM15 Dexron II/III ATF 24 Clockwise
KBW10D 3GMD Dexron II/III ATF 24 Clockwise
KBW10E 3HM/3HM35 Dexron II/III ATF 24 Clockwise
KBW20 4JHE/4JH2E Dexron II/III ATF 40 Clockwise
KBW20-1 4JH3E Dexron II/III ATF 40 Clockwise
KBW21 4JH-TE/4JH2-TE Dexron II/III ATF 40 Clockwise
SD20 GM/YM SAE 80/90 GL4/5 74 Clockwise
SD30/31 JH up to 56hp SAE 80/90 GL4/5 74 Clockwise
SD40 JH3/JH4 non turbo HP Gear Lube 71 Clockwise
SD40-T 4JH3-TE HP Gear Lube 71 Clockwise
SD50 Replaces SD40 HP Gear Lube 74 Clockwise
YX70S-1 6CX-ETE SAE 30W 169 Bi-Rotation
Transmission Specifications Application
Manufacturer Model AKA Ratio(s) Fluid Type Ounces
Velvet Drive 1005 V-Drive 1.2:1 / 2.5:1 DEXRON II/III ATF 28
1017 71 1:01 DEXRON II/III ATF 64
1017 71 1:05 DEXRON II/III ATF 94
1018 72 1:01 DEXRON II/III ATF 64
1018 72 1.52:1 / 2.91:1 DEXRON II/III ATF 94
2001-001 to 006 5000 ALL DEXRON II/III ATF 64
2002-002 to 005 5000 V-Drive ALL DEXRON II/III ATF 94
Walters RV-10 ALL SAE 30W 16
RV-20/26 ALL SAE 30W 33
RV-30/36 ALL SAE 30W 48
RV-40 ALL SAE 30W 64
RV-48 ALL SAE 30W 64
Hurth/ZF HBW40/50 ZF4M/5M ALL DEXRON II/III ATF 10
HBW100 ZF10M ALL DEXRON II/III ATF 12
HBW150A ZF15M-A ALL DEXRON II/III ATF 17
HBW125/150 ZF12M/15M ALL DEXRON II/III ATF 19
HBW150V ZF15M-1V ALL DEXRON II/III ATF 34
HBW250 ZF25M ALL DEXRON II/III ATF 25
HSW250A ZF25A ALL DEXRON II/III ATF 60
HSW250H ZF25A ALL DEXRON II/III ATF 68
HSW450A2 ZF45A ALL DEXRON II/III ATF 68
HSW450H2 ZF45H ALL DEXRON II/III ATF 101
HSW630A ZF63-1A ALL DEXRON II/III ATF 135
HSW630H ZF63-1H ALL DEXRON II/III ATF 128
HSW630V ZF63-1V ALL DEXRON II/III ATF 135
HSW800A2 ZF80-A2 ALL DEXRON II/III ATF 186
HSW800V1/V2 ZF80-1V/2V ALL DEXRON II/III ATF 236
IRM220A ZF220A ALL SAE 30W 135
IRM220PL ZF220 ALL SAE 30W 135
IRM220V-LD ZF220V ALL SAE 30W 169
IRM220V-2 ZF220V ALL SAE 30W 135
IRM280A ZF280A ALL SAE 30W 135
IRM280PL ZF280P ALL SAE 30W 135
IRM280V-DL ZF280IV ALL SAE 30W 202
IRM301A ZF301A ALL SAE 30W 220
IRM301PL ZF301C ALL SAE 30W 220
Engine Oil (Note for older models refer to your manual- manual is correct):
Sailboat Supplies, Engine Parts and Boat Parts
Yanmar Engine Oil and Fuel Capacity Engine Model Quarts of Oil* Oil Type** Quarts of Coolant*
Recommended Coolant
1GM10 1.6 15W40 N/A YG30R or DexCool***
2GM20F 2.1 15W40 0.77 YG30R or DexCool***
3GM30F 2.7 15W40 0.9 YG30R or DexCool***
2YM15 1.9 15W40 3.2 YG30R or DexCool***
3YM20 2.6 15W40 4.3 YG30R or DexCool***
3YM30 2.6 15W40 4.6 YG30R or DexCool***
3JH3E 5.2 15W40 5.6 YG30R or DexCool***
4JH3E 5.6 15W40 7.2 YG30R or DexCool***
4JH3-TURBO 7.4 15W40 7.2 YG30R or DexCool***
3JH4E 5.3 15W40 4.8 YG30R or DexCool***
4JH4E 5.8 15W40 6.4 YG30R or DexCool***
4JH4-TURBO 6 15W40 7.6 YG30R or DexCool***
4LHA-TURBO 13.7 15W40 14.8 YG30R or DexCool***
6LP(A)-TURBO 10.6 15W40 14 YG30R or DexCool***
6LY(2)A-TURBO 21 15W40 21 YG30R or DexCool***
6LY3-TURBO 20 15W40 30 YG30R or DexCool***
4BY 8.5 5W40-SYNTHETIC 10.6 YG30R or DexCool***
6BY 11.5 5W40-SYNTHETIC 14.3 YG30R or DexCool***
6CX-ETE 24 15W40 38 YG30R or DexCool***
6CX-GTE(2) 23 15W40 38 YG30R or DexCool***
6SY-TURBO 29 15W40 42 YG30R or DexCool***
8SY-TURBO 35 15W40 79 YG30R or DexCool***
* Capacity levels should be considered approximate.
** Engine oil specifications will vary by location.
*** All new / replacement installations of Antifreeze in Yanmar engines must include the following specifications:
Silicate - free
Phosphate - free
Organic acid base
Protects all metals including Aluminum
Meets or exceeds ASTM D3306 &D4985
Long Life
Contains no borates, nitrates, amines, or nitrites
alctel (08-19-2014)
post #17 of 33 Old 05-30-2014
Sounds like you rub the fluid on your finger, and if it is red, use Dexron III. If it is brown, use SAE30(ND).
Unless you've got one of the SD models, in which case, you'll be going shopping.
Or did I miss another option?
post #18 of 33 Old 05-30-2014
casey1999's Avatar
Some transmission use gear oil.
post #19 of 33 Old 05-30-2014
Gear oil: I thought that was the SD series, using the same 75W90 range that many auto differentials and some manual transmissions use. I've seen SAE30 in Honda, 75W90 from Toyota, I'm sure there are others. But the vast majority of the non-ATF on your list are SAE30.
post #20 of 33 Old 06-01-2014
christian.hess's Avatar
that list is good, but interesting nonetheless
I have a 2qm15 I was about to buy and the kanzaki kbw10 transmission CLEARLY STATES atf OR sae30 oil
Merit 25 sold...Islander 36 still afloat? who knows...Im still in Columbus, and back...I think...jajajaja!!!!
christian.hess is offline
Yanmar 2GMF Transmission Oil? dacap06 Gear & Maintenance 4 04-19-2010 11:03 PM
Yanmar 3GMD Timing happyman Diesel 1 11-22-2009 03:48 PM
yanmar transmission dissasembly hertfordnc Gear & Maintenance 2 02-11-2009 11:58 AM
Yanmar 3gmd Question nk235 Gear & Maintenance 4 03-12-2008 04:48 PM
yanmar transmission rbtpfe9 Gear & Maintenance 0 09-06-2005 10:46 AM
