Yanmar 3GMD transmission oil confusion in manuals - Page 3 - SailNet Community
 3Likes
post #21 of 33 Old 06-01-2014
Re: Yanmar 3GMD transmission oil confusion in manuals
"CLEARLY STATES atf OR sae30"
If it is that versatile, you could just pour in old bacon grease. That's either the world's most versatile gearbox, or a translation error.
hellosailor is offline
post #22 of 33 Old 06-02-2014
christian.hess's Avatar
I can take a pic for you...its in english...
typical kanzaki kbw10 tranny found on 2 cylinder yanmars
and here you go from here on sailnet:
Kanzaki/Hurth KBW10 Transmission trouble
cheers
I should correct its the old 20/30 hd, which means you can use either 20 or 30 weigh straight grade again HD...
I used atf in my old yanmar
Merit 25 sold...Islander 36 still afloat? who knows...Im still in Columbus, and back...I think...jajajaja!!!!
christian.hess is offline
post #23 of 33 Old 06-02-2014
casey1999's Avatar
cheers
Interesting. I am surprised Yanmar would have such a wide range of lubricants. I know of older BMW cars that when the manual transmissions are hard to shift (especially in below freezing temps) some have used ATF in the gear box instead of the recommended gear oil- and it seems to have worked.
christian.hess likes this.
casey1999 is offline
post #24 of 33 Old 06-02-2014
I have seen many transmission or gearcases spec different oil and or lubes depending on whats available
for example many recomend atf now especially the dexron 4 stuff which is really good
here is an interesting tidbit too
many motorcycle suspension shops and or mechanics prefer to use dexron 4 atf for their suspensions as the detergents and antifriction properties as well as antifoaming agents are preffered over the overpriced "suspension" fluid
its also widely known that many fork fluid is simply rebranded atf...but wuth 3 or 4 times a higher price
x2 on your bmw comment...
in any case...the kanzaki trannies are pretty robust and im sure any old bacon grease can work for a while
if it were me I would use what it had in there before me or if you want to change I would tear it apart clean meticulously and use your preffered lube, be it oil or atf...having said that, some clutches and or plates or disks will retain a fair amount of the old lube in them even after cleaning so its at your own risk when doing that
for example in wet clutch engines or motorcycles plenty of folks get all sorts of mad when simply switching brands of oil...or when they switch to an energy conserving oil...and creat all sorts of havoc...
in some cases its the oil...others its the owners not rinsing or sufficiently eliminating the old traces of oil from the clutch
anywhoo
post #25 of 33 Old 06-02-2014
"I can take a pic for you...its in english..."
"I should correct..."
Ergh...correct to what? SAE 20/30 HD and not ATF, ATF was a different tranny?
I wasn't thinking of a translation error on your end, but rather from Japanese (?) into Ynglitch. Some of the "manuals" I've gotten from the Orient are incredibly funny. Go back 40 years or so, and many/most of them were crude-to-adequate. Hell, even Toyota, who were fairly big in the US at that point, had some odd phrases in their US car manuals.
I've learned that nothing is impossible (except getting anyone to do anything right or on time the first time) I'd just always heard that gearboxes were made for one or the other, never ATF and motor oil each good in the same box.
And that there's usually a reason specific lubes are used. While a number are "good enough" to misuse, there's usually some long term benefit in using the right one. Even better if you can get it off-label cheaper, sure, as long as it is the same stuff.
post #26 of 33 Old 06-02-2014
hellosailor the kanzaki transmission states you can use EITHER that doesnt translate to mix at will
thats what I was saying...
ps although the kanzaki trannies are indeed made by yanmar use whatever the TRANSMISSION plates says to use...
post #27 of 33 Old 06-02-2014
I know exactly what you are talking about...rebuild old honda motorcycles and stuff and youd be hard pressed to get halfway through without going nuts
having said that its pretty simple to see what the plate on you tranny says and use that
to note is that kanzaki (at least the kbw10 tranny) did change later models to only use atf...
post #28 of 33 Old 06-02-2014
Christian-
Yes, I'm clear on either, not both at once. And that's still possibly the only maker or only gearbox I've ever heard of that says that. (In the little I know about gearboxes.)
That either makes it so incredibly advanced, or, such a crude old monster that it just has toothed gears on shafts that don't really care what they eat, I guess. Sometimes old, crude, simple machines that run forever is better than having finicky new ones that work better--but not as reliably.
post #29 of 33 Old 06-02-2014
thats exactly what it is...a disk and some gears and thats that
there is a saying in the old motorcycle world or motor world that ANY oil is better than no oil
so when in doubt just put something in...deal with it later
post #30 of 33 Old 06-08-2014
Over Hill Sailing Club
smurphny's Avatar
Sometimes I wonder if the foreign companies that write translated service manuals ever bother to hire a native English speaker to try to make indexing and searching logical. Sometimes I wonder what they were thinking when a simple topic requires a three step procedure to make any sense of it. I have the service manual for my 3GM30F and have spent hours at times trying to find answers to the simplest questions like WHAT KIND OF OIL to use:-) It has all you'd ever want to know but it takes time to sort it out. I've run into the same issue with electronic equipment manuals. They are printed in English but seem almost nonsensical in the way they are organized and the way topics are explained.
smurphny is offline
Yanmar 2GMF Transmission Oil? dacap06 Gear & Maintenance 4 04-19-2010 11:03 PM
Yanmar 3GMD Timing happyman Diesel 1 11-22-2009 03:48 PM
yanmar transmission dissasembly hertfordnc Gear & Maintenance 2 02-11-2009 11:58 AM
Yanmar 3gmd Question nk235 Gear & Maintenance 4 03-12-2008 04:48 PM
yanmar transmission rbtpfe9 Gear & Maintenance 0 09-06-2005 10:46 AM
