Yanmar diesel white smoke - SailNet Community
post #1 of 4 Old 10-19-2010 Thread Starter
Yanmar 3GM30F I have white smoke coming out of my exhaust, only on load, Oil pressure good, temp good, no loss of coolant. Plenty of water out of exhaust. No smoke when at idle. I had some bad fuel but had it polished. changed filters three times. changed oil it looked good, no water. any ideas?
hooligan6a is offline
post #2 of 4 Old 10-22-2010
Steam?
Whats the air and water temp where you sail?
Is it using oil?
SJ34 is offline
post #3 of 4 Old 10-22-2010
How long do you run the engine? Does it clear up or all the time?
That derelict boat was another dream for somebody else, don't let it be your nightmare and a waste of your life.
badsanta is offline
post #4 of 4 Old 10-24-2010
DrB
Most likely dirty prop
Sounds like you have a dirty prop or bottom. When the motor is under load, it works to move the boat. When prop/bottom is dirty, the motor must work harder to move the boat, which puts a strain on the motor more so than a clean prop/bottom. Hence, you see more smoke.
Your smoke is probably a mix of steam and unburnt fuel. When was the last time when to prop/bottom was cleaned?
DrB
If you liked my advice/response, give me some rep points. If you didn't......well what do you expect, it was free.
DrB is offline
Problem starting Yanmar 2QM20H and white smoke when running epp Diesel 10 07-30-2010 01:20 AM
white smoke and overheating on MD7A dobravila Diesel 14 07-06-2010 06:24 PM
white smoke in exhaust SeaSteward Gear & Maintenance 13 04-17-2008 10:26 AM
White Smoke Alden68 Gear & Maintenance 31 03-27-2007 10:49 AM
White Smoke from Older Diesel at Higher RPMs kcoffey Gear & Maintenance 3 06-24-2004 03:23 PM
