Refilling fresh water cooling circuit on a Volvo MD7B - SailNet Community
post #1 of 3 Old 10-22-2010 Thread Starter
Recently I tried for the first time to replace the impeller and gasket on the fresh water pump. I removed the front plate to access the old impeller and obviously all the coolant from the block and the heat exchanger poured into the bilge. I've put in the new impeller and screwed the faceplate back onto the pump. Now I'm wondering how should I refill the system with the right amount of coolant in order to avoid air bubbles. Start the engine and keep pouring coolant into the heat exchanger until it overflows? Or should I fill the recovery bottle and let the pump siphon the coolant back into the cooling circuit? I have no idea...
Also, what is the recommended mix of coolant and water to be used in this particular heat exchanger? 50/50? Regular water will do or do I need distilled water?
Any help will be appreciated.
galliard is offline
post #2 of 3 Old 10-22-2010
JimsCAL's Avatar
50/50 mixture is correct. Same as an auto. You can buy it premixed if you want. I wouldn't start it dry and filling throught the recovery bottle won't work. Top off through the cap on the heat exchanger, run the engine and add as necessary. It may take a bit of bleeding to get all the air out of the system.
JimsCAL is offline
post #3 of 3 Old 10-24-2010 Thread Starter
All the information I needed, thanks so much.
galliard is offline
Fresh Water cooling water dirty brown sailak Gear & Maintenance 17 07-31-2009 11:52 PM
MD6A cooling water circuit.. groundhog Gear & Maintenance 0 09-11-2008 05:37 PM
convert from sea water to fresh water cooling.... john232 Gear & Maintenance 3 02-16-2004 03:44 PM
Fresh Water Cooling Volvo MD17C Nereus32 Gear & Maintenance 0 07-17-2002 12:19 PM
Fresh water cooling conversion tsawyer Gear & Maintenance 1 03-22-2002 06:17 AM
