Volvo MSB reverse gear - SailNet Community
post #1 of 5 Old 10-26-2010 Thread Starter
Hi All.
I am new to this forum but not to boats/Diesels. I have a boat with Volvo MD17C and Variable pitch prop. The shaft is screwed directly into the end of the direction slide mechanism and then the gearbox. No flexible coupling.
I want to change the prop shaft and put in a fixed prop and shaft.
Question:
The gearbox has a stop on the reverse gear direction so it cannot be used. (It would unwind the shaft and all the wrong issues would ensue). Does anyone know these boxes well enough to tell me if it should work in reverse if I remove the stop? I tried once and nothing happened. Could this just be gunk on the clutch? ( I live in hope as the alternatives are out of my budget).
Fingers crossed
StillWet is offline
post #2 of 5 Old 10-26-2010
the pointy end is the bow
erps's Avatar
did you try rotating the shaft a bit one way or the other when trying to slip it in reverse? My guess is that the sliding cone clutch has worn the portion of the shaft between neutral and forward and that the shaft splines probably have a bit of a "step" to the transition to reverse.
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
erps is offline
post #3 of 5 Old 11-05-2010 Thread Starter
Thanks ERPS.
I got it into gear OK but it didn't rotate the shaft. Could there be gunk on the clutch perhaps?
I will give it another try tomorrow and let you know how it goes,
Thanks again for your reply.
Greg
StillWet is offline
post #4 of 5 Old 11-05-2010 Thread Starter
Hi Again.
I got the gearbox into gear but no rotation. Any ideas? Could there be a gear sproket missing?
I will have to look for a used gearbox and hope it is ok. I have not seen many advertised. I suspect most people assume that it is too old to bother with and throw into the land fill.
Fingers crossed..
Greg.
StillWet is offline
post #5 of 5 Old 11-05-2010
Total guess here but a 'missing gear' is likely - and the main preventative measure to inadvertant reversal. The stop was probably to give the solid stop on the linkage.
Faster is offline
Wanted: Volve Penta MS or MSB reverse reduction gear assy erps Gear & Maintenance 3 10-10-2015 05:45 PM
Volvo MD7A Missing reverse gear dipstick ifreilich Gear & Maintenance 3 04-26-2009 02:36 AM
MD7A Volvo Penta Timing Gear shebobah Gear & Maintenance 5 10-27-2008 03:23 PM
Gear confessional: what was the last piece of gear you bought merlin2375 Gear & Maintenance 60 07-05-2008 10:45 AM
Volvo MD5 reduction gear JohnGalt Gear & Maintenance 0 07-02-2004 10:44 AM
