What Gear for Yanmar While Sailing - SailNet Community
post #1 of 8 Old 11-08-2010 Thread Starter
casey1999's Avatar
What gear should you put a Yanmar engine in while sailing?
Reverse to stop the prop or neutral.
I have seen where Yanmar issued a notice that the transmission should be placed in neutral and not fwd or reverse gear to prevent clutch damage. I have a 3GM.
Thanks, Casey
casey1999 is offline
post #2 of 8 Old 11-08-2010
Maine Sail's Avatar
Neutral is the Yanmar suggestion.
______
-Maine Sail / CS-36T
Maine Sail is offline
post #3 of 8 Old 11-08-2010
Gene T's Avatar
Yanmar recomends neutral. But if you have a folding/feathering prop you will want to use reverse.
Gene
Currently in Long Beach, CA
Gene T is offline
post #4 of 8 Old 11-09-2010
As others have stated Yanmar says neutral. With a folding prop, I've heard that its "OK" to switch briefly into reverse to feather the prop, but return to neutral. I've wondered if this is right?
capecodda is online now
post #5 of 8 Old 11-09-2010
Zanshin's Avatar
For years the official Yanmar recommendation was to put the gear in reverse and only recently did they change their policy, so briefly putting the gear in reverse after turning off the engine in order to fold the gears shouldn't be a problem. That is what I do, although I usually forget to do that and only do a quick switch reverse and back to neutral when I get that humming sound from below while sailing.
Yanmar Advisory MSA08-003 "Gear in Neutral While Sailing"
Zanshin is offline
post #6 of 8 Old 11-13-2010
Shortman's Avatar
and does that stop the humming? I haven't tried that with my Kiwiprop.
Shortman is offline
post #7 of 8 Old 11-13-2010
Shortman,
With a Maxprop it seems to stop the rotation...humming.
post #8 of 8 Old 11-15-2010
Zanshin's Avatar
Originally Posted by Shortman View Post
...and does that stop the humming? I haven't tried that with my Kiwiprop.
Yes, the humming comes from the partially folded prop still turning in the water flowing past it. Putting the engine into gear stops the shaft and the prop folds completely and then has no tendency to turn anymore even after the shaft is put into neutral.
Zanshin is offline
1978 yanmar 2qm20 fuel in oil. from gear and maint forum AUBERGINE Diesel 10 08-11-2012 01:45 PM
YANMAR - Gear Position While Sailing Maine Sail Diesel 32 05-21-2012 09:41 PM
First Day of Sailing - Gear? trailblazer1229 Learning to Sail 3 04-16-2010 02:24 PM
Dexron ATF in my Yanmar Trans Gear? jason3317 Gear & Maintenance 29 12-16-2008 08:02 PM
1983 Yanmar 1GM engine -- Oil for Gear Case H216Sailor Gear & Maintenance 11 04-05-2008 09:56 PM
