How to plug up fuel and water hose holes? - SailNet Community
post #1 of 4 Old 11-17-2010 Thread Starter
Sailing to surf
Beersmith's Avatar
I am in the process of disconnecting hoses, wiring and shaft from the engine to prepare for pulling it from the boat. When I remove a fuel hose (or water hose), how should I cap the connection it was attached to? I had planned on just stuffing some paper towel in there, but I figured there would be a more professional and safe method of capping those holes.
For reference, it is a Yanmar 4JH2E.
My boat rebuild/sailing blog:
Beersmith is offline
post #2 of 4 Old 11-17-2010
kd3pc's Avatar
a more reliable way would be to find a bolt similar to the line size that the hose went on...and simply reclamp the hose on that ....
if you want to get pricey snapon/matco have billet blanks of normal sizes to replace the bolt or rod stock...
best of luck
kd3pc is offline
post #3 of 4 Old 11-17-2010
MacGyverRI's Avatar
are you plugging the hose or block?
most garages and parts stores have those plastic caps that are made for that.
hose, bolts like kd said or some wooden dowel stock cut for a plug.
block, short piece of hose w/ any of the above
duct tape over block fittings also works well.
Ken, East Prov., R.I. Bootlegger, PY26 Paceship
If you like my posts, or they were helpful, please click the "scales" icon on top right to add Rep points.
MacGyverRI is offline
post #4 of 4 Old 11-18-2010 Thread Starter
Sailing to surf
Beersmith's Avatar
thanks for the help!
Fuel fill hose yachtthor Pacific Seacraft 2 01-17-2010 04:12 PM
Fuel Filler Hose Replacement rheaton Gear & Maintenance 9 09-19-2007 07:12 AM
Water hose Danielle Gear & Maintenance 3 12-24-2005 03:30 PM
Fuel fill (pipe) to (hose) adapters pjfsail Gear & Maintenance 2 09-26-2004 09:30 AM
fuel hose odor stm Gear & Maintenance 0 01-20-2003 02:13 PM
