Diesel 'Crush Test' - SailNet Community
post #1 of 20 Old 11-19-2010 Thread Starter
Diesel 'Crush Test'
So..how many of the diesel 'dorks' know what a 'Crush Test' is and what it's used for..??
aa3jy is offline
post #2 of 20 Old 11-19-2010
5hortBu5's Avatar
From what I've managed to google-fu, it's to ensure that everything's seated correctly on a crush-type washer. I'd guess you tighten everything up, then remove it again and check the crush pattern.
I'm seeing a bunch of stuff like "repeat injector copper washer crush test to verify correct crush pattern."
I'd probably wait for a real diesel geek to show up and give us the what-for, though.
5hortBu5 is offline
post #3 of 20 Old 11-19-2010
One of None
deniseO30's Avatar
Sitting on the captain's lap?
My last project!
deniseO30 is offline
post #4 of 20 Old 11-19-2010
Allanbc's Avatar
The diesel crush test is when you crawl under the engine and then wiggle it to see if the engine mounts are secure.
"When in command, command." -- Admiral Nimitz
Difference between a power boater and a sailor out on the water: A power boater is going some place special, a sailor is already there.
s/v Zotz 1981 Pearson 365 Ketch Hull #375
Allanbc is offline
post #5 of 20 Old 11-19-2010
the pointy end is the bow
erps's Avatar
I've not heard that term before. There was a product called plastiguage that was crushed between the crankshaft and bearing to indicate the clearance between the two, but that product wasn't specific to diesel motors.
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
erps is offline
post #6 of 20 Old 11-19-2010
MacGyverRI's Avatar
Is this engine specific or general for any engine? I've never heard the term either.
Deutz air cooled diesels required a piece of solid core lead solder to be crushed between the head and piston after the head is bolted on, then it's removed and miked to see the clearance since it doesn't use a head gasket. The cylinder to head seat carbon seals itself like an old VW engine. (A few others also use that method)
added;
Pencil type injectors (cat/perkins etc.) also have a crush washer on the face seat to seal them and it could refer to that.
Ken, East Prov., R.I. Bootlegger, PY26 Paceship
If you like my posts, or they were helpful, please click the "scales" icon on top right to add Rep points.
MacGyverRI is offline
post #7 of 20 Old 11-19-2010 Thread Starter
Hint..Mack Boring and my yard performed this 'Test' on my ailing 3GM30F...
aa3jy is offline
post #8 of 20 Old 11-19-2010
Courtney the Dancer
jrd22's Avatar
Crush washers I've heard of.
The plastiguage stuff Erps mentioned I've heard of.
Crush test - no clue.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
jrd22 is offline
post #9 of 20 Old 11-19-2010
One of None
deniseO30's Avatar
Hates tests
My last project!
post #10 of 20 Old 11-20-2010
islander bahama 24
newhaul's Avatar
as a retired shipwright that owns 4 road diesels the only diesel specific crush test i know is to torque the injectors and then inspect the crush pattern on the copper washers. there are other crush tests however none are specific to diesel.
Illegitimus Non Tatum Carborundum.
newhaul is offline
New crush -- Ensenada 20 bobmcgov Boat Review and Purchase Forum 7 10-09-2011 06:37 PM
alternator test - diesel engine parvenu Gear & Maintenance 8 12-22-2009 08:21 PM
Test a diesel on the hard? GBurton Gear & Maintenance 8 08-13-2007 07:50 AM
Auto Diesel vs Marine Diesel / Addatives NewsReader Mass Bay Sailors 0 07-11-2007 06:15 PM
Ultra low sulphur diesel and the older marine diesel Valiente Gear & Maintenance 2 10-20-2006 12:10 PM
