Burning engine oil ...I think - SailNet Community
post #1 of 25 Old 12-13-2010 Thread Starter
trantor12020's Avatar
After 160 hrs (3 weeks period) of running my Yanmar 2GM20F, I've found only 1/2 litre of luboil left in the engine crankcase when I pump it out. Since I found no oil in the bilge or engine drip pan I suppose the lost oil has been burnt in the piston. Question is, is this the sign of wore piston rings?
Ken
2002 Hunter 326, SV Millennium 2
1999 Macgregor 26X, SV Millennium
trantor12020 is offline
post #2 of 25 Old 12-13-2010
Needing Apehanger Helm
HDChopper's Avatar
More than likely , but it could also be burnt valves or bent or non seating valves all on the normal side , esp on an engine designed for old world gas new gas ( unleaded) requires stellite valve seats to say the least...
unleaded gas burnt in an older eng designed for leaded gas will polish the cylinder walls like a mirror , make valves stick & burn ect....
if diesel then just the first part about rings and valves ...
Hope that helps....
EDIT: yep just saw this is the diesel side of things lol...
There is no right way to do the wrong thing
HDChopper is offline
post #3 of 25 Old 12-13-2010
MARC2012's Avatar
Are you sure all the oil was removed from the engine?marc
MARC2012 is offline
post #4 of 25 Old 12-13-2010
Courtney the Dancer
jrd22's Avatar
I'm not familiar with the oil capacity of a 2gm, but if you ran it with only 1/2 liter in it I think you would have soon heard lot's of noise and then it would seize up since that wouldn't be enough oil to prime the oil pump. I'm with Marc above that you did not remove all of the oil for some reason. When you checked the oil level before running the engine everyday (?) did you notice the level consistently getting lower until it disappeared off the stick entirely?
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
jrd22 is offline
post #5 of 25 Old 12-13-2010
Warm Weather Sailor
Vasco's Avatar
There's probably another 2 liters left in the crankcase. Are you sure you got it all out? How much was in the filter?
Rick I
Toronto in summer, Bahamas in winter.
Vasco is offline
post #6 of 25 Old 12-14-2010 Thread Starter
Quite certain 1/2 litre left. I pump it out into a 1.5 litre pet bottle which filled to 1/3 volume. Poured in 2 litres+ after changing the filter. Well engine still ran fine with 1/2 litre of oil and that surprises me. So if the rings are wore, can it be change without removing the whole engine? Do I suppose just by taking out the tophead and mid block I can have the piston rings changed?
Ken
post #7 of 25 Old 12-14-2010
HDChopper's Avatar
I couldn't find a IPB for your eng. here YANMAR Diesel Power - GM/YM Series Marine Engine
Personally I would try everything & anything to find out more like compression test to say the least before you start digging into your eng.....
On most engines one would have to remove the crank shaft to do piston rings correctly Unless the cylinder / cylinders can be taken off the top of the block .. you did say "mid block" this means to me that would be he cylinders.
try simple thing like using a wood dowel that fits in the dipstick hole loosley ( not just a stick off a tree) to touch the bottom of the crankcase pan once you think it's empty to verifiy it really is before you believe it only had 1/2 liter in it ...
allways check everything before takeing your eng apart ... you may have no problem at all hopefully..
Hope this helps ...
post #8 of 25 Old 12-14-2010
Don Radcliffe
If your engine is burning enough oil to require a rebuild, you will see LOTS of blue-grey smoke. Like enough to see where you've been for the last 10 minutes. The best test is to track consumption on the dipstick--depending on where your pump inlet is located, you may be removing only a fraction of the oil in the sump. See Yanmar 2GM Oil Change Suggestions
donradclife is offline
post #9 of 25 Old 12-14-2010
Courtney the Dancer
jrd22's Avatar
If I understand correctly you ran the engine for 160 hours without adding any oil and then when you changed it there was only .5 liters of oil in it, correct? And like Don states above you didn't see a lot of blue smoke, both at startup, and while running? And while the engine supposedly only had .5 liters of oil in it the low oil pressure alarm didn't go off, or the pressure guage (I don't know what you have) didn't read abnormally low? Something isn't adding up here.
John
SV Laurie Anne
jrd22 is offline
post #10 of 25 Old 12-14-2010
Compression test, and if that's questionable you can do a leakdown test. If you can get a recommendation to a local diesel mechanic, not just someone who claims to be one, pay for a looksee.
Oil can be funny, sometimes there's a pint or more hiding in the filter, sometimes you haven't sucked what you think out of the pan, sometimes it is being sucked past the rings. At this point, do some testing before you start to worry. Carry some spare oil & check the dipstick in the meantime, no crisis.
hellosailor is offline
Video of replicate wooden ship burning jgsteven General Discussion (sailing related) 2 07-31-2009 03:00 PM
NH boater rescued from burning boat - WCAX NewsReader News Feeds 0 06-28-2007 08:15 AM
Burning Questions about Water Heaters oft Gear & Maintenance 4 08-12-2006 07:42 PM
Man's body found on burning sailboat - KESQ NewsReader News Feeds 0 04-26-2006 09:15 AM
