Why fuel filters must be changed - Page 2 - SailNet Community
post #11 of 14 Old 01-09-2011
pdqaltair's Avatar
Originally Posted by RichH View Post
Not quite! The enzymes DISSOLVE (disperse) the fungal colonies and puts the very small sized 'debris' into solution so that it can easily pass through common 'filters'.
Not quite! A LOT of the water in fuel is in an emulsified state (finely divided on a non-visible macromolecular scale held between the fuel molecules) plus molecular (sized) water due to chemical equilibrium ... and the biologicals can extract their needed 'water' directly from the partly water saturated fuel and don't need 'free' water in the bottom of the tank.
Not quite! Dispersed (not dissolved) colonies are not DEAD colonies. They can repopulate the system. Filters cannot remove all bacterial, because individuals are sub-micron.
Not quite! I said no water, and I really meant free and emulsified, since that is all a sailor can see. Bacteria cannot use true dissolved water (single molecules) at rates large enough to cause growth; it needs to be in larger packages (micron size is enough) for colonies to form. But the point is often unimportant; if the fuel is close to saturation, free water will form due to temperature cycling unless the boat is used and a good dispersing additive is present.
Just playing with you! Everything you said was "almost" true.
The central point is that the OP understand that 1/2 cures lead to repeat troubles.
Writing full-time since 2014
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is offline
post #12 of 14 Old 01-09-2011
Maine Sail's Avatar
Not quite! The enzymes DISSOLVE the fungal colonies and puts the very small sized 'debris' into solution so that it can easily pass through common 'filters'.
Rich,
Very interesting to hear you support this product and I am a little surprised because my experience with it was not very good. I used it twice, Startron Enzyme Diesel Fuel Tank Cleaner, and my tank still looked like the inside of a tar factory. It didn't even make my filters clog any faster which I would have expected after a "cleaning". Perhaps it was worse before I cleaned it but on this boat there is really no way otehr than an inspection camera to get to the tank and clean it out short of removing it from the vessel... Snake oil is about the best term I can come up with for for this product claiming to "clean" tanks..
Personally I am not sold on the SolTron or StarTron products for actually "cleaning" or dissolving anything but it does tend to make my transom stay slightly cleaner, less soot, so I continue to use it...
As you said a physical scrubbing is the best the Startron left it like this...
______
-Maine Sail / CS-36T
Maine Sail is offline
post #13 of 14 Old 01-09-2011
RichH's Avatar
Maine
Physical scrubbing is the obvious best method, principally because you must 'visualize'.
When first using the "tank cleaner" I naturally had 'snake oil' trepidations;
but, I have prolonged/doubled my cleaning interval from every year to two years with the Startron product ... as I find that it doesnt 'loosen' the debris deposition; rather, it seems to slowly put the crud into 'solution' (& without plugging the filters) and that does takes time. I do semi-continually operate an onboard polishing system, so my large tank doesnt have the chance to become as fouled as yours, even after being in the 'tropics' for past several years.
Ive also started using the 'tank cleaner' in my multiple home heating oil tanks ... and yes, it does seem to be slow acting but is positively reversing a 40+ year old very thick deposition layer and without clogging the filters or flame nozzle.
With respect to the 'cleaner stern', I would expect that too as most enzymatic action makes 'smaller' particles which would have an enhanced probability of being 'more completely burned' in the combustion chamber, rather than 'surviving' the combustion chambers and being deposited in the exhaust leg.
Suggest you give the 'tank cleaner' more soak time and if possible do this in the heat of the summer for the thermally enhanced reaction rates. Im still in the 'learning curve phase' of using such tank cleaners and so far my observations are it does take a quite a bit of time but doesnt have the disadvantage of 'loosening' a LOT of crud which would create a 'particle storm' of the larger particles. More patience!
RichH is offline
post #14 of 14 Old 01-09-2011
Maine Sail's Avatar
Maine
Maybe I will give it another shot. That was after 15 years + of Soltron/Startron and two tank "cleanings". The PO a buddy of mine did spend many years with the boat in warm climates and I suspect that is where a lot of the growth came from.
With my new tank I have a dedicated high flow polishing system, per discussions with yourself and many other industry experts, and so far it has work fabulously but was designed when building the tank. I would have gone pressure, as you suggested, but when I spoke with Racor they were pretty adamant that they wanted the pump on the suction side for better water removal benefit.
I am using a Carter rotary vane pump @ 72 GPH on a 32 gallon tank. Amazing results thus far..
New Fuel Tank & Polishing System
______
Fuel Filters for Dummies Classic30 Diesel 4 07-20-2010 07:25 PM
fuel filters bog69 C36 0 10-24-2009 08:24 PM
Diesel Fuel Filters roline Gear & Maintenance 2 09-27-2009 01:33 PM
Why Change Fuel Filters at end of season and at beginning of season? theArchitect Gear & Maintenance 1 11-24-2007 07:37 PM
Diesel fuel filters ahoyjim General Discussion (sailing related) 0 01-06-2006 06:47 PM
