oil in air intake - SailNet Community
post #1 of 3 Old 01-13-2011 Thread Starter
oil in air intake
Yanmar 2gm won't start since installing new starter, I've been working on other engine projects since the new starter like changing oil, fuel filters, changing zincs replacing worn hoses, and bleeding the lines. This past weekend I noticed oil coming out of the air intake. Any advice?
rvarnes is offline
post #2 of 3 Old 01-13-2011
Of all that work, bleeding the fuel lines is probably the most likely, IMHO. Try again?
Do you mean the oil breather is dripping oil? That's not terribly uncommon if it's a very little. If a notable amount, you may have blockage or blow by in the cylinders. If she ran well very recently and before you began this work, I would doubt either. Can I assume you are certain you didn't overfill the oil?
Edit: did you flip a compression release lever intentionally to bleed or by accident?
Minnewaska is offline
post #3 of 3 Old 01-13-2011
Irrationally Exuberant
I'm with Minnewaska--I'd check the oil level--2GM takes 2 quarts I believe.
Tom K
2000 Beneteau 331
Northern Chesapeake Bay
arf145 is offline
Diesel Air Intake sachemgfp Pacific Seacraft 6 09-23-2010 03:11 PM
Air intake on Westerbeke 13? Tanley Diesel 2 05-28-2010 06:36 AM
Yanmar Intake Silencer vtsailor11 Gear & Maintenance 4 05-26-2009 03:35 PM
Raw Intake Screen Stu01 Gear & Maintenance 6 10-08-2008 12:43 PM
raw water intake rchad Gear & Maintenance 12 06-26-2008 08:19 AM
