Daf 575 engine 'Hunting" - SailNet Community
post #1 of 5 Old 01-21-2011 Thread Starter
I have a DAF 575 diesel engine in my boat. Another boat owner told me my engine was "Hunting" as he sailed away. The engine has done about 4000 hrs and never misses a beat.
Is "Hunting" worth doing anything about? Thanks for your interest. J
GEWA is offline
post #2 of 5 Old 01-21-2011
the pointy end is the bow
erps's Avatar
I think hunting refers to a motor that has an oscillating rpm. That is that it speeds up, the governor kicks in to slow it down, it slows down too much, the governor kicks in to speed it up. Does your motor do that?
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
erps is offline
post #3 of 5 Old 01-21-2011 Thread Starter
It only seems to happen at very low (almost idling ) revs. I hadnt noticed it being a problem until the comment was made by this other boater.
GEWA is offline
post #4 of 5 Old 01-21-2011
erps's Avatar
If it only does it while idling, I probably wouldn't worry about it. You might try adjusting the idle speed up or down a tad, to see if you can find an RPM near idle speed where it doesn't lope. I don't know enough about that particular motor to give any other advice.
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
erps is offline
post #5 of 5 Old 12-21-2012
mjk
Re: Daf 575 engine 'Hunting"
Might be a bit of a late reply, but hunting by this engine at low rpm/idle/cold is perfectly normal. And not worth adjusting.
Many older engines have this issue, and if you do adjust this you might sacrifice responsiveness in some other area of the rpm band.
Hope this helps
M.
mjk is offline
Cal 25 engine storage "bulkhead" - structural? Whippersnapper Cal 0 03-31-2010 11:33 AM
What should/shouldn't you keep in the "engine room?" FishFinder Gear & Maintenance 4 07-28-2009 09:05 PM
Role of engine in DC "boat ground potential" floatsome Electrical Systems 19 04-12-2009 05:22 AM
"Saildrive" Engine? SEMIJim Gear & Maintenance 22 06-18-2007 08:19 PM
C270 Main Sail "stack Pack", Quick Cover", "lazy Bag" Install randy22556 Catalina 1 02-28-2007 11:53 AM
