-   Diesel (http://www.sailnet.com/forums/diesel/)
-   -   Open 12 V switch on Yanmar 4JH4-TE (http://www.sailnet.com/forums/diesel/71627-open-12-v-switch-yanmar-4jh4-te.html)
sypsyche 01-26-2011 08:01 AM
Yanmar 4jh4-TE reduces the 12 VDC voltage from the starting switch to the engine Oil switches, relay or other switches, to 5 VDC. My Smart Regulator asks for: "It must be turned on with a normally open oil pressure switch, ignition relay, or other switch that has no other loads on it to cause a voltage drop or "sag". The switch/relay should produce 12 VDC when engine is running.
I have been advised by a Yanmar dealer not to cut into the harness. How do I connect the alternator "Smart Charger" to the Yanmar?
Any one?
tommays 01-26-2011 08:11 AM
If i understand you need 12 volts and the motor running ?
The key switch should be 12 volt and could run a relay before its taken down to 5 volts
You could also go with a second oil pressure switch BUT i dont like the extra plumbing and risk of breaking when you start hanging extra stuff
casey1999 01-26-2011 03:59 PM
Oil Pressure sender
I have the Yanmar 3GM. If I want to fit a oil pressure sender to the engine, what do you suggest. I assume I want to add a fitting to the existing oil pressure switch but will this extra plumbing cause a problem or break and leak oil?
sypsyche 01-30-2011 01:49 AM
Open 12 VDC
Thanks for your reply. Could I connect the smart charger sensing wire directly to the ignition switch (12 VDC) without the use of a relay?
