Toyota 4 cyl conversion sump design - SailNet Community
post #1 of 4 Old 01-29-2011 Thread Starter
I am planning to fit a Toyota 4 cyl diesel automotive engine into my own design 29 foot boat. I could do with some input on sump design. I have done all the basic conversions and have fully rebuilt the engine. I understand the sump needs extra baffle plates to prevent oil surge as well as a deep well for the oil strainer. Any input or comments would be much appreciated. I have built and fabricated just about everything on this boat and want to get the motor right now. Also where is the best position to exit the exhaust? Ideas to prevent water ingress thru the exhaust?
afunytingapend is offline
post #2 of 4 Old 01-30-2011
mitiempo's Avatar
Hi
Can't help with the sump but here's a diagram from Yanmar that should help with exhaust layout.
Brian
mitiempo is online now
post #3 of 4 Old 01-31-2011 Thread Starter
Hey Brian thanks a span! That diagram is just what I need and that configuration makes a lot of sense.
post #4 of 4 Old 01-31-2011
Make sure you put a seacock in the exhaust line if you're planning on making any bluewater passages. In heavy seas, the seas can force enough water into the exhaust system to hydrolock the engine, so you need to have a way to close it off when sailing in such conditions. When motoring, it isn't an issue, since the exhaust pressure keeps the water out.
sailingdog is offline
AC / DC Lighting – a stylish design solution for the design obessive DIY… artbyjody Electronics 0 11-03-2009 02:33 PM
Toyota series at JASC (Khaleej Times) NewsReader News Feeds 0 09-21-2006 01:21 AM
Toyota Sailboats continue JohnManzano Boat Review and Purchase Forum 14 01-01-2004 06:06 PM
Toyota Sailboats?? JohnManzano Boat Review and Purchase Forum 16 12-24-2003 05:13 AM
