Kanzaki shift fork - SailNet Community
post #1 of 2 Old 02-08-2011 Thread Starter
Reformed powerboater
TheBlackPearl's Avatar
Send a message via AIM to TheBlackPearl Send a message via Yahoo to TheBlackPearl
Kanzaki shift fork
Hi all, i know that the parts availability for older Kanzaki transmissions is getting quite scarce, and the horse has been beat to death - however i'm curious if anyone out there has had the shifting fork replaced or rebuilt in theirs, and if they have had any luck. I'm not talking about "Red-Green'ing it", if i can't repair/replace the fork properly then i'll bite the bullet and wait until i can afford a replacement trans.
I have a 3QM30H Yanmar mated to a Kanzaki KH-18 (i believe... it's been awhile since i crawled under there or opened up the service manual) and the trans. went out. The shift fork is worn down and can be adjusted to either shift into drive, or reverse, but not both. I've talked to a few mechanics about the possibility of rebuilding it and all three said that i could have it brazed and built back up if i had the specs for it. I have the factory service manual but am curious if theres someone who has gone through the same headache on theirs.
Unfortunately the 1-year rebuild on the boat has turned into a 4-year rebuild that necessitated gutting the interior down to the stringers to deal with rot. Budget tells me that the money isn't there this year for a new several-thousand-dollar transmission, so what are your thoughts folks?
Waves are not measured in feet or inches, they are measured in increments of fear.
TheBlackPearl is offline
post #2 of 2 Old 02-13-2011
ncarter's Avatar
shift fork
I have a spare tranny.. left over from a repowering.. send me a PM if you are still in need. : neal_carter@verizon.net
ncarter is offline
Turnbuckles: difference between jaw and fork nickspacek Gear & Maintenance 7 08-03-2010 11:41 AM
Hurth HBW-5 won't shift mwielicki Gear & Maintenance 1 04-16-2010 11:55 PM
Hard to shift Poundsey Gear & Maintenance 0 07-22-2009 12:47 PM
Cal 2-29 shift cable Jbradac Cal 1 05-16-2008 05:21 PM
At sea. Volvo Ocean Race: ABN AMRO TWO has 50 knot winds with100 degree shifts & fork lighting @ BYM Sailing News NewsReader News Feeds 0 04-18-2006 04:15 AM
