Wrenching - SailNet Community
post #1 of 11 Old 02-27-2011 Thread Starter
LakeSuperiorGeezer's Avatar
Wrenching
About turning a wrench, the other part of the learning besides studying the books is how to turn a wrench so that you do not bang your knuckles and take some skin off. Just think about where the wrench is going to go when you turn it. Better yet, have sockets with extensions and ratchets to drive it that put you above anything you can run into with your hands. Sometimes a nice jerk will get things moving. Of course when doing assembly, use a torque wrench because getting it correct is very important, too tight and you break it, not enough and it can come loose. Generally a mechanic gets large bolts not tight enough and small ones too tight. When using a screwdriver, it the screw is tight, put the screwdriver on the screw and just as you start to turn the screw, push yourself away using the screwdriver to do so. This momentum puts more pressure downwards on the screw than you can do by just pushing down on it. All you have to do is turn the screw a very little bit to break it loose so once you get it started, you can just turn it in the ordinary way.
Buy decent tools. It does not have to be Mac or Snap On, the really expensive tools. No need for the absolute best. If you look in a mechanics toolbox, you will mostly see Craftsman. I like twelve point sockets, but sometimes six point is what will turn the bolt that has rusted down to a smaller size, or even tap a metric socket onto a fractional socket. When it comes to rusty bolts that do not want to come loose, there are penetrating oils that will soak into the rust in a few hours and the bolt will come loose. Heating the bolt or nut up with a torch will also loosen it. There is also a tool called a nutcracker that tightens down on a nut that splits it down the side with a chisel like wedge driven into the side of the nut. Usually rusty fasteners are not a problem for the average mechanic but in a marine environment it can be more of a problem so I mention it here.
Get the shop manual read the manual very carefully. Have it there in front of you as you work. I copy the pages from the manual I am interested in and get thos greasy rather than the book. Usually an engine manual is an instruction book intended for the mechanic that is not familiar at all with the engine, or I should say someone learning to be a mechanic. Instruction covers things you would think would be in a general manual on engine repair, general knowledge, but there it is in a good shop manual, a self contained book telling you how to become a mechanic.
LakeSuperiorGeezer is offline
post #2 of 11 Old 02-27-2011
My rule:
Always push a wrench with an open palm... and don't pull straight at your own nose!
Faster is online now
post #3 of 11 Old 02-27-2011
My rule:
Both good suggestions, but sometimes pulling is an evil necessity. BTW, pulling is better than pushing with a closed hand.
sailingdog is offline
post #4 of 11 Old 02-27-2011
Senior in age only!!!
centaursailor's Avatar
All good info, but it takes years of practice to get everything right.
I,v been at it for 40+years and still get the odd scrape. Getting the size right is the most important factor. Lots of slips are as a result of a using the nearest rather than the right size spanner.
Well fitted ring spanners are better then most tools but don,t suit every job.
Easing oil before dismantling if you have time helps. Working in confined spaces make care and planning more important than ever.
Never ever use vice grips or pliers instead of proper tools.
My son recently gave me a pair of fingerless "Kevlar"? gloves. They are great saving nicks and cuts.
Safe sailing
The great appear great because you are on your knees. James Larkin, Irish Labour Movement.
centaursailor is offline
post #5 of 11 Old 02-27-2011
I don't discuss my member
zz4gta's Avatar
It amazes me how many people don't know how to use hand tools. It amazes me even more how many refuse to wear gloves. After 5 years of building and racing cars, you realize how important your hands are.
Merit 25 # 764 "Audrey"
zz4gta is offline
post #6 of 11 Old 02-27-2011 Thread Starter
Safe sailing
Where do you get those gloves? I want a pair!
post #7 of 11 Old 02-27-2011
bljones's Avatar
Ding, ding, ding! Mechanics gloves are cheap enough now, I've got a pair in every toolbag, and every vehicle. In addition to protecting your digits, you can also generate more torque when you're less worried about your hands coming to harm.
It's 5 o'clock somewhere:
bljones is offline
post #8 of 11 Old 02-27-2011
He got them at work, hes a construction plumber. I see lots of different styles on ebay or try your local motor parts and tool shop.
Safe sailing
post #9 of 11 Old 02-27-2011
BarryL's Avatar
Good thread.
A few from me:
  • Use a 6 point socket instead of a 12 point (if possible). The 6 point is less likely to round the nut or bolt
  • Always try to turn the nut and not the bolt (this isn't always possible, but do it if you can).
  • Clean things before you start taking them apart. This way you will be able to see all the bolts that are holding parts together. You won't get dirt and grit into places they don't belong. It will be easier to find parts you drop. You will stay cleaner too
  • Don't use adjustable or 'monkey' wrenches. Ever. Your hands will thank you. The parts you don't break will than you. They don't call them 'knuckle busters' for nothing.
That's about it for now.
Barry
Barry Lenoble
Deep Blue C, 2002 C&C 110
Mt. Sinai, NY
BarryL is offline
post #10 of 11 Old 02-28-2011 Thread Starter
Hand Cleaner
I find that the usual hand cleaners are not very good at getting grease and dirt out from under and around fingernails. Scrubbing with a fingernail brush and cleaners with pumice still leaves crevices in the hand looking rather black with greasy dirt. However, I have found that if I take just a little of the BlueMagic 5215 Invisible Glove Protective Hand Coating and rub it into the ends of my fingers, that it leaves a film that fills these crevices on the hand and then hand cleaner takes care of the rest of the oily dirt. After application, I wave my hands around to dry them. I do not use this product over all of my hand as I find it a little irritating on the back of my hands if I use it a lot. It contains Water, glycerin, sodium silicate, soap, and fragrance. It leaves a strong film and I can feel what I am doing with my fingers which is not the case with rubber gloves
